Curious about intake gaskets
Old Jan 14, 2011 | 03:42 PM
jag1886's Avatar
Why does Oldsmobile use shim steel intake gaskets? I'm sure there is a reason but no one I've ever known knows why.
Old Jan 15, 2011 | 08:10 AM
Rickman48's Avatar
If you're talking about the 'bathtub' type - to keep the hot oil off the stock intake manifolds - less heat transfer.
Old Jan 15, 2011 | 08:25 AM
Is that REALLY the reason?
I mean, with all due respect, with an open exhaust heat riser channel and a heat riser valve from the factory that was restrictive even when open, and all of the heat generally inherent inside an engine anyway, would the additional oil splash really make a difference, or is that just an urban myth of some sort?
Old Jan 15, 2011 | 11:37 AM
Oldwolf's Avatar
Good question, I´curious to.
Stanley
Old Jan 15, 2011 | 05:16 PM
jag1886's Avatar
Keeping hot oil off the intake could be it but I doubt that's why Olds did it. I know back in my SB Chevy days they did build a baffle for under the manifold that was there to stop hot oil from getting on the bottom of the manifold when using a cold air intake with no heat cross over.
Old Jan 15, 2011 | 07:09 PM
The Stickman's Avatar
Could be more about protecting the oil from the hot crossover area.
Old Jan 16, 2011 | 08:41 AM
Destructor's Avatar
Supposedly that is what it is for, so that oil doesn't bake to a hard sludge and end up falling into the valley. My Chevy 305 had a pan rivited to the underside of the intake manifold over the crossover.
82 Grocery Getter
Site Help
Apr 30, 2009 03:08 PM
78cutlass
Site Help
Jan 25, 2009 05:39 PM
54olds
Brakes/Hydraulic Systems
Jun 25, 2008 12:46 AM
BlueBlock350
Mar 28, 2008 01:51 PM
Molly
Mar 23, 2008 07:20 AM
