Crossover pipe bolt dilemma
Old Oct 18, 2013 | 05:30 AM
at3reg98's Avatar
New 2 Olds
Question Crossover pipe bolt dilemma
I removed my crossover pipe to do some work and can't for the life of me drill the bolts out of the exhaust manifolds. Removing them to do on the bench isn't an option for me. This is on my '83 and the project has been stalled since May as a result.
My question is, would it be cheaper for me to bring the car to a muffler shop or my regular repair shop to have it taken care of? Or would it not make a difference? I thought I read somewhere that the quickest, easiest way would be to melt the remnants out with a torch and I'm thinking the muffler shop would be better equipped to tackle that, thus cheaper. Opinions?
Old Oct 18, 2013 | 05:43 AM
droptopron's Avatar
delete
I'd think a muffler shop would deal with issues like that more often
Old Oct 18, 2013 | 06:47 AM
So you've been stalled for five months because you can't remove the manifolds?
Why not just remove the manifolds?
Old Oct 18, 2013 | 07:15 AM
halfmoontrail's Avatar
Spend some money and some really good drill bits (cobalt?), in a few sizes, starting smaller, maybe 1/8". Use a dremel with a cutoff blade to cut a cross in each bolt, to provide a centered starting point for the smallest drill bit. When you are done, instead of tapping your new hole, you can use a throughbolt instead.
Steve
Old Oct 18, 2013 | 08:32 AM
^^^This!
Old Oct 18, 2013 | 09:27 AM
at3reg98's Avatar
New 2 Olds
^^^This!
I can just about guarantee the exhaust manifold bolts will snap off in the head. Not exactly easy access on the smogger 307 either. That and the AIR tubes will crumble if disturbed. Not about to pull the engine on this thing yet.
Old Oct 18, 2013 | 09:45 AM
Then take it to a muffler shop, and they will drill through approximately where the bolts were, and install through-bolts.
Without a lift, you'd be a glutton for punishment to be doing it on your back.
Old Oct 18, 2013 | 09:47 AM
The A.I.R. tubes screw into the heads above the manifolds. You should not need to touch them. All but the center manifold bolt are in through holes - spray a good penetrating oil in the backside and let them soak overnight. Frankly, if the motor is this rusty, you have other problems.
Old Oct 18, 2013 | 09:56 AM
at3reg98's Avatar
New 2 Olds
In that case maybe I'll have some luck then, I'll have to give that a try. It's not terribly rusty, just the usual corrosion. I've been busy with my '65 I haven't really looked at it. Ideally I would get them off and take them to a machine shop and do it right. Good tips, good tips.
Old Oct 18, 2013 | 10:05 AM
The other tip is that an impact wrench works wonders on rusted fasteners. I realize that space is limited to reach the manifold bolts, but if you can use a right angle impact, you'll have those bolts out with no concerns.
Old Oct 18, 2013 | 11:11 AM
Also, depending on what else you're in the middle of, and other circumstances, sometimes you can remove a fender liner and get close to a straight shot at the manifold bolts from the side.
Old Oct 18, 2013 | 11:26 AM
at3reg98's Avatar
New 2 Olds
Well went to remove one and it snapped off like I expected. It's a puny 12mm nut on a stud. Not removing the manifolds..
Old Oct 18, 2013 | 11:59 AM
I'm not familiar with the later cars, but I thought all exhaust manifold screws had 9/16" heads and were 3/8"x16 threads.
Old Oct 18, 2013 | 05:38 PM
jag1886's Avatar
I understand if you don't use a torch and heat things up cherry red you get a lot of broken bolts on through bolts.
I don't understand way you can't drill out the broken ones, tell use who you are attempting to do this, I have done this many times and maybe it's just your technic.
1964super88
Sep 10, 2014 02:47 PM
56Super88
Jun 1, 2012 03:18 PM
deadmanscurve
Jan 27, 2012 05:22 AM
shaks 442 clone
Mar 29, 2008 08:31 PM
66f85deluxewagon
Jan 21, 2008 11:49 AM
