crankcase pressure
crankcase pressure
I have 75 350 that am wanting to know if I run a oil breather cap on the oil fill tube allowing the eng internal pressure to escape then do I still need the pcv and valve cover breather?am wanting to install the built alu valve cover's that have no provision's for the breather's or pcv. thanks in advance.......jim
BUT JOE I HAVE AN ELDERBROCK INTAKE ON THE 350 AND ARE WANTING TO RUN THE ALL ALUM FABERCATED VALVE COVER'S THAT DONT HAVE PROVISIONS FOR PCV OR BREATHER THOUGH I DO HAVE THE OIL FILL TUBE WITH A BREATHER ON IT, STILL NEED THE PCV?
You need a breather someplace in the crankcase. That can be the oil fill tube, for example.
OK, I HAVE A BREATHER IN THE OIL FILL TUBE NOW. SO WITH THAT I CAN INSTALL THE ALUM VALVE COVER'S THAT HAVE NO PROVISION'S FOR PCV OR BREATHER AND BE OK WITH CRANKCASE PREASURE ? /> T
The PCV valve has nothing to do with balancing the pressure within the crankcase. Although it does provide vacuum, the purpose of the pcv valve is to remove combustion gases from the crankcase which result due to blowby. In order for the PCV valve to function properly there also must be some type of breather for fresh air to enter through, however, the use of a breather alone is not enough. You must use a pcv valve system of some type in order to remove blowby from the crankcase because this blowby contains some unburned fuel which can potentially wash out bearing surfaces such as the cam and lifters. Without a PCV system the oil must be changed very frequently in order to not allow the blowby contaminants to build up.
No, what I was trying to say is that you need the PCV in one of the valve covers or in the intake and you also need a breather of some type, either in the other valve cover or in the oil fill tube.
Originally Posted by Wise Geek
........ Another violation of forum etiquette is posting in ALL CAPS. This is considered shouting and is very rude, in addition to being hard on the eyes. Something may be in caps for emphasis (e.g. I did NOT want to go!), but no post should be entirely in all caps ........
88coupe, didnt realize that caps was a screaming at people thing but will refran using it, not very good at this computer thing, am sorry if Ive insultated anyone...
