Correct cooling fan 72 olds no AC?
Old April 24th, 2022 | 06:18 PM
Mac1911's Avatar
Currently it has a 4 blade solid
Not sure if its supposed to have a shroud and a fan clutch ? Currently its just a small metal guard over the fan?
Old April 24th, 2022 | 07:07 PM
70sgeek's Avatar
'72 Cutlass ragtop
Model / drivetrain info would be helpful but in general, full shroud, a 5 or 6 blade fan and thermal clutch would be typical to find on an a/c car. Possibly no clutch fan for non-a/c and maybe 4-blade fan standard, but I think full shroud would have been standard across all models
Old April 24th, 2022 | 07:14 PM
66SportCoupe's Avatar
4 blade no shroud is standard
Old April 25th, 2022 | 04:32 AM
Mac1911's Avatar
Thank you , I will post pics later , customer complains car runs hot. I personally have not seen it over heat while we have had it.
I dont know what hes judging by the “runs hot”
He has a 40 year old aftermarket tri gauge in there now and god knows how accurate that is.
Old April 25th, 2022 | 04:34 AM
Mac1911's Avatar
sorry its a 72 cutlass engine 350 olds , trans ?
For the most part the car is original other than carb and exhaust. All be it a 50 year old mess
Old April 25th, 2022 | 05:11 AM
What temp is his aftermarket gauge showing at extended idling? He may be going through the never-ending cycle of overfilling and having it puke out coolant due to no head space.
Old April 25th, 2022 | 09:34 AM
Mac1911's Avatar
it bounces all over the place,
Will rin up to about 230-240 then drop to 200 and then bounce around 200-230
I think the gauge is more of the problem?
Old April 25th, 2022 | 09:56 AM
That sounds more like an air pocket to me if they are rapid swings.
Old April 25th, 2022 | 03:48 PM
Mac1911's Avatar
where do you think air pockets are coming from.
Other than head gasket?
Old April 25th, 2022 | 03:59 PM
It usually happens when the cooling system is low and refilled. You get a steam pocket in that sensor area.
Old April 26th, 2022 | 03:32 AM
Mac1911's Avatar
installing new hoses and overflow tank this week , I will use the vacu-fill to make sure there is no air.
Thanks again
Old April 26th, 2022 | 05:38 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Do a thermostat as well, it could be sticking closed at times. You could do a 160 or 180 temp thermostat. How does the radiator look inside? I used that exact set up, including a recored at one point, had an old tag, 2 core orginal Copper/Brass radiator in my 70S. I did run CLR through it and really flushed the crap out. I never got over 195 with a 9 to 1 Olds 350 at a stop light. Going down the highway, it ran at thermostat temperature or very close. Good luck.
Old April 26th, 2022 | 05:47 AM
If it is a customers car, stick with a 180* thermostat as the 160* will not provide much heat if they drive in colder climates.
Old April 26th, 2022 | 02:50 PM
Mac1911's Avatar
we replaced the clogged radiator a while back with the duel core A/C opption
Old April 26th, 2022 | 07:39 PM
Agree, more to burn off condensation than heat output, a 195 is needed for max heating. I highly doubt if heat is priority in a 50 year old car, crazy to drive these in the Winter. The 180 thermostat is plenty of heat, even into our cool spring and fall.
Old April 27th, 2022 | 07:30 AM
Mac1911's Avatar
thanks guys
I will report back after I do the hoses,T stat and over flow tank.
Car is in much need of love and deep pockets. Older Customer is trying to get a few more cruise nights out of it.
Old May 2nd, 2022 | 01:56 PM
Mac1911's Avatar
Originally Posted by Mac1911
thanks guys
Well thanks guys
Customer supplied the puke tank and I wish he bought at least something more factory looking.
That , Fresh Thermostat. And coolant and all seems well. Almost ready for extended road test. Its running - touch over 200 by the AM gauge set.
Been off the road for at least 7 years and last I laid my hands on it was 2011 , installed a new battery and a Generic battery hold down.
72GoldOlds350
April 25th, 2020 12:59 AM
Eastflorida
July 21st, 2017 01:23 PM
goldie442
August 9th, 2014 08:11 AM
vmathy
August 26th, 2011 05:22 AM
4speedBench
August 23rd, 2010 03:14 PM
Quick Reply: Correct cooling fan 72 olds no AC?
