Correct AC Belt for 1987 307
I need a new AC belt for the Cutlass, VIN Y application.
I went to Autozone and the belt they gave me is way too small.
The old belt no longer exists... so I have nothing to compare it to. Any help is appreciated.
I used a Delco 15-443 belt back in '94 but that part number is no longer valid. Belt is still on the car, though.
Rockauto shows this one - ACDELCO Part # 15585 {#88934366} HC41 13/32" x 59 1/8".
Ironically, this is the same belt my '72 uses, too!
I guess you should have just ordered the belt for an '85 Toro then, rather than a Cutlass.
Rockauto specs that one you just got.
GATES Part # 7520 High Capacity V-Belt (Standard); HC41 13/32" x 52 5/8"
Was this for your Toro or a Cutlass you also have?
craftsmen22
July 17th, 2011 08:52 PM
