cooling system flush
Old Apr 3, 2014 | 12:50 PM
jason's Avatar
Looking for suggestions on how to flush the cooling system on a 68 cutlass. Just repaired timing cover leak and filled with straight water. The water just looks dirty. Thinking about garden hose in top of radiator and opening drain **** and running until clear. Would this work?
Old Apr 3, 2014 | 12:58 PM
Just get one of those Prestone flush kits that's on the rack in every parts store, then go to the hardware store and get a double-female garden hose adapter to replace their low-flow check valve version, and let 'er rip.
Old Apr 3, 2014 | 01:13 PM
jason's Avatar
OK I will get one. Which heater hose does it go to, the one going to water pump or back of intake? Also do I need to take a rad hose off?
Thanks Jason
Old Apr 3, 2014 | 01:18 PM
All you need below, just follow the directions.
Old Apr 3, 2014 | 01:19 PM
Instructions are with the unit. Frankly I don't remember which hose you cut.
You don't need to take the radiator hoses off, but you can, and you can jam a garden hose into any hose opening you see and give it a go.
I'd also remove the block drain plugs (usually four of them, 2 on each side, but it can vary) to flush the rusty gunk out of the block - sometimes these don't run at all when you pull them out, because there's so much stuff packed into them.
If the block seems rusty inside, it may help to run a flushing product in there for a week or two, too.
Finally, put antifreeze in it as soon as you're done, as straight water will just promote more rust and corrosion.
Old Apr 3, 2014 | 01:24 PM
76olds's Avatar
Hookers under Hood
I would add a bottle of water pump lubricant after the flush and fill.
Cincinnati Rick
Brakes/Hydraulic Systems
15
Feb 2, 2015 04:21 AM
scrappie
Sep 16, 2012 04:07 AM
radioburningchrome
Aug 10, 2010 06:52 PM
jeffreyalman
Jun 7, 2009 04:49 AM
cola
Feb 16, 2008 10:27 AM
