Comp Cams or Cloyes Timing Set
Old Aug 30, 2011 | 06:07 PM
oldzy's Avatar
Just wondering which is better. Comp Cams dbl (3113) or the Cloyes true dbl roller (9-3113). The Cloyes is twice as much, so that b meaning it be better? I already have a Comp Cam hyd. roller cam if that matters. tx
Old Aug 30, 2011 | 06:11 PM
Doug Blake's Avatar
Cloyes always
Old Aug 30, 2011 | 06:15 PM
oldzy's Avatar
I am going to throw this one as well. Just seen it on RA's site.
CLEVITE / PERFECT CIRCLE Part # 93113
Performer;High Performance Street Applications and Slightly Modified Racing Engines;Contains Better Quality Double Roller Chain With .250" Diameter Rollers, Cast Iron Cam And 3 Key Crank Sprockets $78.03
Old Aug 30, 2011 | 07:02 PM
380 Racer's Avatar
Comp Cams gear and chain are made by Cloyes.
Old Aug 30, 2011 | 07:15 PM
coppercutlass's Avatar
Chevy budget Olds powered
i have always run the comp cams roller set never had an issue
Old Aug 30, 2011 | 07:47 PM
henryk8398's Avatar
Hangin' out...
x2 That's what I always heard!
Old Aug 30, 2011 | 08:39 PM
Lee_A's Avatar
I've used the Summit house-brand timing sets on some motors with fairly big solid rollers, and had no problems.
There are probably no more than 2 or 3 companies actually making these and selling them to EVERYONE.
At one time, while working on several Pontiacs, I had timing sets from 3 different companies - they were identical, right down to each chain having one silver link.
Lee
Old Aug 30, 2011 | 08:57 PM
oldzy's Avatar
Thanks.
Looking at Cloyes a bit more, they have several options, and several do not seem to be straight bolt-ons. The all-billet ones look appealing though (ie. http://www.summitracing.com/parts/CLO-9-3613X9/). Not sure which would be preferred degree wise though (ie. 2/4, 4/8, 3/6, etc.)
http://www.summitracing.com/search/B...?Ns=Price|Desc
Old Aug 31, 2011 | 05:02 AM
cutlassefi's Avatar
If you want to do it right, then get the Cloyes 9 keyway setup. Also look for roller size, bigger is better, the Comp has smaller rollers.
And a lot of the mail order stuff uses american made sprockets but chinese chains, that's what stretches.
Sircajun
Apr 15, 2015 02:49 PM
Smitty275
Jul 19, 2014 01:02 AM
scooter123
Dec 16, 2013 12:20 AM
at3reg98
Jul 30, 2013 04:01 PM
