Chart/specs for flow on SBO heads
Are there any spec/charts for the flow or port sizes on the various SBO heads?
I have seen some experienced Olds enthusiasts suggest both the #4 and 5's ... probably the 5's suggested most as best flowing. I haven't seen any data are specs regarding....
First, all of these "head flow" charts are typically based only on measurements of one or two heads. The manufacturing tolerances are greater than the differences you find in these tables. Bottom line is that any SBO head prior to the no. 8 smog heads will flow about the same as any other, given the same valve sizes. People loose WAAAAY too much sleep agonizing over this.
Yes and #8's with a bowl hog on the exhaust bowl match early heads for flow. The later number then large "A" heads, all suck and need port work to flow as much as earlier heads.
Toocool
February 15th, 2018 12:34 PM
QS442
April 12th, 2016 07:58 AM
shaks 442 clone
October 18th, 2008 09:41 AM
