Carburetor for 215 cu
Hello,
My 1963 Cutlass F-85 has a 215c.i. engine, automatic transmision and a Rochester carburetor quadrajet
( I dont know if this is the carburetor of factory or it has been replaced and before there was a 2 barrel)
If I want replace the carburetor because a lot damaged, which model I must try and is better for my engine? (always quadrajets,4 barrel)
You know a precise model that it's Ok (edelbrock, or other)
(now do not exist the aluminium plate with stamped carburetor codes)
Thanks!
Thanks!
Hello,
Thanks!
Thanks!
Thanks for reply,
Over my carburetor there is write "4-jet" ....
Well,
If I have understood well, to part the 4CG, any other carburetor 500cmf Carter AFB or Edelbrock it's ok to mount on my 215 intake manifold.. right?
if not, are you a exact codes of carburetor that I must buy?
Well,
For example, these it's good or not for my old 215 ci ??
it's only for chevy ???
http://cgi.ebay.com/ebaymotors/4-JET...Q5fAccessories
or
http://cgi.ebay.com/ebaymotors/ROCHE...Q5fAccessories
or
or
or
When I used the 500 CFM AFB carb, I still had to get a jetting kit and change the metering rods to suit my engine.
Hallo![Smile](https://classicoldsmobile.com/forums/images/smilies/smile.gif)
As you will see there where different 215 cui engine types offered in 1963.The F-85 got 155 hp and a 2bbl carb,the Cutlass F-85 185 hp and a 4bbl carb.
Our car is a Cutlass F-85.Because the Rochester was worn,our dealer mounted a Holley 8050 Carb.The engine works very well with this part![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
Martin
http://www.britishv8.org/Articles/GM...tification.htm
Martin
TECH9TWISTA
July 7th, 2011 07:42 AM
yeahbuddy
June 1st, 2010 05:38 AM
<sonicguru>
April 2nd, 2007 04:29 AM
