Carb spacer good idea?
Old Aug 25, 2012 | 12:55 AM
bdub217's Avatar
Kickin' It Oldschool
Anything to gain from this?
Old Aug 25, 2012 | 10:15 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Usually only in engines with 400+ horsepower.
Carb spacers will actually make your motor bog if you already have too much plenum volume. I put a 1"spacer on a stock'ish 455 and it lost 1.5 tenths in the quarter mile, and the 60' went from 1.87 to 1.94
Old Aug 25, 2012 | 10:24 AM
Dave Siltman's Avatar
Usually the spacers are for high-end (rpm) horsepower. I don't think the normal street engine would see any benefit and like the previous fellow stated may actually COST you power.
When I was racing small-block Chevrolets I used the spacer and found a coyple extra horses but this was a high-revving engine with a LOT of gear and converter:--NOT on the street.
Old Aug 25, 2012 | 02:37 PM
bdub217's Avatar
ah okay - i guess if i'm gonna have an application that puts 400+ hp i won't even need that as to there will be a root kit super charger on it
Old Aug 25, 2012 | 03:41 PM
Texas69's Avatar
I can't speak to the performance issues, but adding the 1" spacer between the Edelbrock Performer Intake and Edelbrock 1406 4BBL on my 350 solved some fuel boil issues that caused my car to stall out when hot.
Old Aug 25, 2012 | 04:05 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have that one. Being a 4 hole, supposed to help bottom end. Maybe using a spacer is killing me at the track. I tried a 4 hole and open 1" spacer, made no difference at the track.
Old Aug 25, 2012 | 05:41 PM
cutlassefi's Avatar
Wow! Bad info here.
Here are the facts;
Adding a spacer has little to do with the rpm range, see my intake test in the big block section. You're effectively adding plenum volume so if the intake and/or carb are too small for the rest of the combo then typically it will benefit from one.
If the carb and intake size are correct normally it won't. But by making the air/fuel take a less severe turn into the runner some benefit may still be realized.
Old Aug 25, 2012 | 11:13 PM
bdub217's Avatar
are you saying less turbulent air coming in with a riser? less turbulence is good IMO
Old Aug 25, 2012 | 11:19 PM
ah64pilot's Avatar
The bottom line is that the engine you would be putting it on won't magically wake up and tell you "how you durrin?" Save your money for the 350 or 455 you're gonna build one day and drop in that thing
Old Aug 26, 2012 | 10:08 AM
bdub217's Avatar
Thumbs up
I figured as much.
I'm gonna have to build a BB.........
I don't think chicks are into "Hey wanna check out my smallblock?"
...............That song pops in my head "STROKE ME STROKE ME!"
Billy Squire anyone?
Old Aug 28, 2012 | 07:10 AM
jpc647's Avatar
Did you buy a spacer like this? Or one of the insulating gaskets that E-Brock recommends? There's a difference. (Honest Question, not trying to be a smart-as*).
Old Aug 28, 2012 | 04:46 PM
Texas69's Avatar
Spacer
JPC647
I got a similar part Mr. Gasket Part No. 3404 - 4 hole spacer. Did the trick for me on the fuel issue. Your results may vary.
dynamic63
Apr 19, 2014 09:46 AM
gearheads78
Aug 7, 2009 04:00 PM
chaos
Mar 18, 2008 05:42 AM
71HolidayCutlass
Jul 26, 2007 09:08 AM
