Carb Spacer ?
Old Apr 10, 2013 | 10:45 AM
yankees's Avatar
Carb Spacer ?
What spacer works on an Edelbrock 3711 intake with a 72 cutlass flat stock hood? All stock engine. 4 hole or open spacer on the 3711?
Old Apr 10, 2013 | 11:02 AM
What carb are you using?
Old Apr 10, 2013 | 11:32 AM
yankees's Avatar
Either a Holley 650 DP 4777 or possibly a Holley 750 Vac Sec 3310
Old Apr 10, 2013 | 11:50 AM
That manifold is dsigned for either a spreadbore or squarebore carb. So no spacer is required, as I'm assuming no EGR either.
I'm going to try this on mine next.
http://www.summitracing.com/parts/hly-108-18
Currently I use this:
http://www.summitracing.com/parts/sum-g1417
Old Apr 10, 2013 | 01:21 PM
hookem horns's Avatar
May need a 1" spacer under the Holley to clear the EGR port on the 3711. I have an aftermarket air cleaner so not sure about stock. The 3711 is not high rise like the RPM and I think the dimensions are pretty close to stock.
Old Apr 10, 2013 | 01:35 PM
I'm using a 3310 Holley on a Performer manifold on BBC, no spacer with just the gasket above. I'm also using an old Corvette 14"x3" drop base open aircleaner. I tried using an Edelbrock carb but could not find and aircleaner to fit under my flat hood. With you having a SBO there is not a clearance issue.
bdub217
Aug 28, 2012 04:46 PM
62radarlove
Feb 26, 2012 12:25 PM
defiant1
Sep 19, 2010 06:44 PM
deadmanscurve
Mar 12, 2009 06:42 PM
65Delta88
Mar 25, 2008 07:18 AM
