Carb Advice - Edelbrock Intake
Old March 5th, 2018, 02:27 PM
tgilligan's Avatar
Hi,
I have the Edelbrock 3711 intake on my 350 currently. It has block off plates for both the EGR and the choke as I converted the QJet from hot-air choke to electric choke. I'm looking to go with a different carb and the Edelbrock website says that the 3711 is to be used with stock 4BBL only. I'm assuming it's for clearance issues with the ports but is anyone else using a 3711 with an Edelbrock carb and if so, which one? Did it require an adapter plate, spacer, etc.?
tgilligan is offline
Old March 5th, 2018, 02:48 PM
Keep the QJet, it's a better carburetor. You won't see any performance gains going from a good condition 750 cfm QJet to that carb.
As for your question, yes, you have to use a spacer for an Edelbrock carb to fit on the Edelbrock intake manifold. Weird, huh?
Fun71 is offline
Old March 5th, 2018, 05:22 PM
tgilligan's Avatar
Unfortunately, keeping the 4bbl QJet might not be possible. I was looking at the Edelbrock 1411 as a comparison to the QJet but with my concerns of the throttle linkage having clearance issues, I was skeptical. Hopefully with the space and the EGR blocked off, this won't be an issue.
Alternatively, I may be able to have the QJet rebuilt/reman'd but I'm pressed for time. Is there a reputable site that I could purchase a rebuilt 4bbl QJet that anyone is aware of? I saw a Jet Streetmaster QJet on JEGS that has the forward facing fuel inlet that I currently have but wasn't sure about it.
Old March 5th, 2018, 06:30 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Contact Ken at Everyday Performance, very happy with my custom 800 cfm Qjet, good price an turn around time.
olds 307 and 403 is offline
StickW31
September 9th, 2012 06:57 AM
svnt442
July 17th, 2011 04:43 PM
seok
March 23rd, 2011 10:55 AM
sx455raidercelticfan
November 19th, 2010 04:01 PM
Prsabordo
April 13th, 2010 06:04 PM
Quick Reply: Carb Advice - Edelbrock Intake
