Caprice Wagon 307 Olds 1987
Old Mar 11, 2020 | 10:40 AM
Dogge's Avatar
Question Caprice Wagon 307 Olds 1987
Good day to you all!
Can someone tell me what this thing is? Looks like there is supposed to be a air/vacuum line connected to it. The number written on it is 7907198. When i google it i find nothing. I saw it hanging when i removed the ecu because i am doing a complete computer delete. Do i need it now i dont have a computer at all? Or can i just unplug it and lay it in the shelf?
Greetings Jeroen Dogge
Old Mar 11, 2020 | 11:00 AM
Sugar Bear's Avatar
It is the MAP sensor (manifold air pressure) it needs intake manifold vacuum if the CCC computer system was operating.
Old Mar 11, 2020 | 11:11 AM
Dogge's Avatar
Wow, so thats maybe why the ran ran so badly when cold?
Old Mar 11, 2020 | 11:16 AM
Sugar Bear's Avatar
It definitely would have made it run less well under all conditions; but, most cold operation problems are carburetor/choke adjustment related. When dialed in the CCC cars ran well.
Old Mar 11, 2020 | 03:09 PM
No, the MAP sensor is on the passenger side inner fender under the hood. That is the barometric pressure sensor. Since the fuel bowl in a carb is vented to atmosphere, changes in atmospheric pressure will change mixture ratio. This is why high altitude cars are jetted differently from sea level cars. The baro sensor may LOOK like a MAP sensor, but it does NOT have anything connected to that port. It must sense atmospheric pressure.
And yes, this is all spelled out in the Chassis Service Manual...
Old Mar 11, 2020 | 07:53 PM
Sugar Bear's Avatar
Thanks Joe, learned something today. It fooled me looking like a MAP sensor.
Old Mar 12, 2020 | 02:55 AM
Dogge's Avatar
Do you maybe also know what this one is for? Now i totally removed my ecu and the wiring loom that was attached. I have this one still plugged in and i dont know if i can unplug it also and lay on the shelf now i dont have a ecu anymore. When hi google it it says clutch relay or something 10034223.
Thanks in advance
Old Mar 12, 2020 | 02:58 AM
Dogge's Avatar
And at last. Does the whole fender needs to come of to get the ecu cables tru the ''floorpan''? Because i think the rubber it runs tru is screwed in place with 2 screws.
Greetings
Jeroen Dogge
Old Mar 12, 2020 | 08:29 AM
At a minimum you have to unbolt the rear of the fender and pull it away from the cowl to access the fasteners that hold that ECU harness in place. I did that on a car in a wrecking yard where I didn't care about damaging the fender.
That relay appears to be the A/C cutout relay.
Old Mar 17, 2020 | 01:48 AM
Dogge's Avatar
Thank you a lot Joe, You have been very helpfull to me!
Greetings,
Jeroen Dogge
Rip
Mar 30, 2018 01:31 PM
jaunty75
Aug 30, 2017 10:54 AM
cfhcar
Feb 6, 2015 12:09 PM
joe_padavano
Feb 15, 2013 12:52 PM
87wagon
May 28, 2012 05:03 AM
