Cam ID needed
Old Feb 3, 2025 | 08:30 AM
tomhartrides's Avatar
Cam ID needed
I removed a camshaft from my 350 yesterday. It has 243450 stamped on the end. Hoping to learn the specs on it. Any help is appreciated. Thanks
Old Feb 4, 2025 | 03:57 AM
BillK's Avatar
Are there any other markings that might identify a manufacturer ?
Old Feb 4, 2025 | 05:07 PM
Bill, thanks for your question. I do not see anything other than the number posted. I'm hoping it is clear in the attached photograph.
File Type: pdf
Old Feb 5, 2025 | 07:26 AM
BillK's Avatar
I looked through all of the common cam catalogs I have and nobody has an Olds number like that. I could be wrong but I dont think GM ever stamped numbers like that on the cams either.
If you are planning to re-use it the best thing might be to just put it back in the engine and put a degree wheel on it and see what it is.
Old Feb 5, 2025 | 07:42 AM
Bill, again thanks. I even tried to look it up with dashes like Comp has their stock numbers with no luck. I appreciate your advice. Tom
Andy
Oct 10, 2022 06:03 PM
Almond900
Aug 11, 2016 06:58 AM
Hairy Olds
May 2, 2016 09:12 PM
John Hancock
Jul 24, 2013 10:48 AM
Mike Hathaway
Mar 23, 2005 08:12 PM
