Broken exhaust manifold bolt in head
Hey everyone. Any ideas on how to get this bolt out? The bolt head broke off but I have about 3/4" of the bolt to grab on to. I soaked it in mineral oil and used vice grips but they just dented the bolt. It wouldn't move. Thanks !
Chris
Chris
Is the head on or off the engine? In or out of the car?
IF off the engine weld a nut to the stud and unscrew it while it is still hot.
If in use heat to get is good and warm and then a very good pair of vice grips
I've had to do this, too. Heat the area all around the screw. You want it VERY hot, but probably not getting to red yet (don't want to crack the cast iron).
You want to use an oxygen-torch (oxy-acetylene, oxy-propane, oxy-MAPP, whatever), not a regular propane torch.
You will find that the exhaust screws screw into their own webs, and most are not blind (depends on the casting, I believe), so you can actually heat the surrounding area pretty well.
Note that four of the five exhaust manifold bolts are in through holes. Only the center bolt is in a blind hole. If this is one of the four, be sure to apply penetrating oil (not mineral oil) to the backside and allow it to penetrate.
You may be able to get away with one of the tiny Bernz-O-Matic Oxy-MAPP torches.
I think they're about forty bucks at some hardware stores. The trick would be to concentrate all the heat you can on the metal around the screw. If you use one of those, you do not need to worry about overheating anything.
![](http://www.homedepot.com/catalog/productImages/300/22/22a6c540-fec5-4d42-b2e0-01f427f12b27_300.jpg)
Also, if you use one of these, you need to have at least 3 bottles of oxygen available - they go fast.
I just went thru removing the center manifold bolt. It broke off when I tried to remove it and I let it sit in PB Blaster spraying it at least every other day for at least 3 weeks. I first tried using a pair of vise grips which are a very good pair and still could not remove it. I then welded another bolt on it and it twisted off. I then determined that someone had used a bolt other than a grade 8 bolt. i never could understand why anyone would use anything but a grade 8 bolt on manifolds
So my next step was then to drill the bolt/stud out first by using a small drill bit and then the next size and then finally one that was just a little bit smaller than the bolt. it came out and I used a tap to ream it out. Very little damage was done to the threads. I was going to use a Heli Coil but it was unnecessary. I was lucky!
The reason why everyone is saying to heat the head and not the bolt is because the metal on the head will expand releasing the bolt. It wasn't mentioned. Just thought I would. Many things that many here assume are known knowledge are really not. Good luck.
4 Barrels of Laughs
Location: I moved to pittsburgh so I can be near Primantis
x2 on the stud remover - its a good set of tools to have in the box. 3/4 inch should be enough to grab. vice grips, sadly are really only good enough for extracting details on enemy troop movements (torture reference...)
keep in mind: there is practically no torque SUPPOSED to be used on an exhaust bolt (usually 20-30ft) so its held in by rust and galling. use PB blaster or ATF+dishwashing detergent (trust me)
if its broken off flush, then the fix sucks more, but usually a small hole and a screw type extractor works. I get leery of the welding method on assembled heads - various valves can spot weld themselves to seats on the grounding path....
4 Barrels of Laughs
sorry I was not back sooner...atf is a wonderful penetrating oil, the dishwashing liquid (very little, not like 50-50) acts as an emulsifier and lets it squeeze in smaller places. I got that one from the ford guys years back...
Ok. Im kind of dissapointed that i couldnt try some of the more exciting remedies, but soaking it in boring old WD40 for two nights worked. Now if only that broken valve cover bolt/bit/extrator would come out that easily!
Thanks guys!
Chris
Thanks guys!
Chris
