best rearend gears to replace my stock gears
Old May 12, 2016 | 01:30 PM
86GutlessCutlass's Avatar
i just put a thumper cam part number 42-600-5 and a b&m 2,000 rpm stall converter and im trying to figure out what the best gears would be so i can still drive it everyday and not have to worry about very poor mileage. i know it is not something to think about when building a car. if need more info let me know. im not sure what the stock gears are. i know there either 2:14,2:29, or 2:41. Thanks, Frank.
Old May 12, 2016 | 02:00 PM
What engine and transmission do you currently have in the car?
Old May 12, 2016 | 02:12 PM
opps, i guess that would be some good info i have a 350 rocket out of a 1978 delta 88 with the 350 turbo transmission
Old May 12, 2016 | 02:15 PM
i also have an edelbrock performer intake on it. and flowtech headers. did you have any problems with your headers sitting on the frame on the passenger side of your car?
Old May 12, 2016 | 05:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
That is a lot of cam for a 8.5 to 1 350. A 2000 stall is small for that cam if it actually stalls there. I say you need at least 3.23 gears but it depends on how much highway driving you do.
Old May 12, 2016 | 05:51 PM
61Bat's Avatar
Agreed, a 3:42 max depends on tire size also.
Old May 12, 2016 | 06:12 PM
I was told that if I went above 2200 rpm stall that my transmission would begin to slip?
Old May 12, 2016 | 07:37 PM
1BOSS83's Avatar
-That is a big overlap cam with a lot of duration that requires a lot of gear for it to perform with any spirit. That said, without an OD trans I am in the camp of the other posts
-No issues with headers, different brand however, That said, the only time I've worked with flowtech headers we had clearance issues (Chevy car)
-These may be helpful if you havn't worked out your wheel/tire combo
To figure rpm: 168 * gear ratio * mph / tire radius
To figure mph: tire radius / 168 * rpm / gear ratio
To figure gear ratio: tire radius * rpm / 168 / mph
To figure tire radius: 168 * mph * gear ratio / rpm
Old May 12, 2016 | 07:48 PM
No. It is in in a 1986 olds cutlass supreme
Old May 12, 2016 | 08:02 PM
1BOSS83's Avatar
I overlooked that previously, sorry about that.
Old May 12, 2016 | 08:17 PM
You will need thick gears for ratios above 3.08 if you use your current carrier. I have a 2200-2500 stall that flash stalls at 2300. It is very tight at lower speeds, pretty good for a cheap converter.You will be above the stall rpm even with your current gearing which should help with slippage.
Old May 13, 2016 | 08:48 AM
My car has a Hughes Performance 2500 RPM stall and during "normal" driving it operates the same as the factory converter. No issues with excessive slippage even at highway speeds when I had to temporarily put in the original 2.56 rear.
Old May 13, 2016 | 09:14 AM
GEARMAN69's Avatar
1. A "thumper" big ole lopey cam isn't going to get good mileage
2. 2000 stall is really not enough rather just a absolute minimum so it will idle in gear without stalling. You would really need a 2500-3000 stall , a big transmission cooler and as said a 3.23-3.73 gear to run good. A 200r4 OD transmission and the proper gear ratio is what you would need to make it run good but mileage is still affected since it is not a mild cam and if you had a lock up 2500 stall it would chug along below its cruise range of the cam.
3. Needs more compression by either milling your heads and doing big valves , pocket port and flat top W31 pistons , or if your running a dish piston run some early 68-72 350 heads, #5,6,7,7a with the smaller chambers
1973olds98
Drivetrain/Differentials
Aug 17, 2010 11:48 AM
jpaulwhite
Ninety-Eight
Aug 3, 2010 08:45 PM
csstrux
Intrigue
Oct 6, 2009 04:41 PM
projectheaven
Feb 5, 2009 09:17 AM
