Anyone running these headers?
Old Nov 18, 2017 | 04:12 PM
GoolzCutlass's Avatar
Wondering if anyone has experience with these headers?
Hedman 58160 Painted Hedder
http://www.jegs.com/i/Hedman/500/58160/10002/-1
Old Nov 18, 2017 | 05:32 PM
truckman5000's Avatar
W30
dont
Old Nov 18, 2017 | 06:14 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Originally Posted by truckman5000
dont
Why not?
Another choice is the Sanderson shorty headers. Thick 3/8" flange and 1 5/8" primary tubes. I ran them on my 88 Cutlass and 1970 Cutlass. Tons of room and can run a full size starter.
https://www.sandersonheaders.com/san...category_id=41
Old Nov 18, 2017 | 06:25 PM
woodie582's Avatar
I am. I like them. Good clearance, thick flange, I have the ceramic finish.
Old Nov 18, 2017 | 06:57 PM
Good to hear someone has some success with them. I got a great deal through amazon and ordered just before I posted the question here. I have had good success with headers on other cars. I couldn't afford the ceramic one but got the painted ones. will get them sand blasted and paint them myself. Now to get the best header paint i can. Any suggestions?
Old Nov 19, 2017 | 07:21 AM
HX3's Avatar
HX3
Originally Posted by GoolzCutlass
.... will get them sand blasted and paint them myself. Now to get the best header paint i can. Any suggestions?
First time using this VHT header paint. The header pictured has approximately 400 miles on it. You'll notice some flaking that is likely from not thoroughly removing the protective oil coating applied to these pipes to prevent rust prior to fabrication and paint. The engine paint is Por-15 and you'll notice some burnt paint right at the exhaust port .. typical of most engines.
Mark
Old Nov 21, 2017 | 04:44 PM
Mr Nick's Avatar
I wish there was a dyno test between these and a full length header on a 400-ish HP SBO. I currently have full length headers, and will be re-doing my exhaust this Spring. I'm tempted to swap to shorties but not if it's going to cost me 20hp & tq across the curve. 5-10 at peak RPM only, I could probably live with.
Old Nov 21, 2017 | 06:52 PM
Nick are you going from longtubes to shorties? why?
Old Nov 21, 2017 | 07:00 PM
Mr Nick's Avatar
Ground clearance and easier to work on other items and do maintenance without full length headers. If I went to shorties, I'd have an approx 90* bend after the collector, then a slip joint on either side of the trans, going into the H-pipe. This could allow me to remove the exhaust in sections and leave the shorties installed, and not have full length headers hanging in the way of the starter, clutch hydraulics, transmission etc.
Also, this car is much more of a cruiser "Power Tour" type car, instead of a weekend warrior like I thought it would be. So giving up a few HP for ground clearance and maintenance might be OK with me.
My car sits pretty low, and I'd like to go a hair lower.
Old Nov 21, 2017 | 07:03 PM
Mr Nick's Avatar
I'll also add, some people don't run full length headers because they may be more prone to exhaust leaks than manifolds. Properly installed, full length headers should be leak free, and these shorties would be no different.
Old Nov 22, 2017 | 05:02 AM
I would think max 10 hp would be all that is lost, tests on other makes show more like 5hp. With my Sanderson's there is a ton of ground clearance and starter is super easy to get to. I plan on swapping to the Hedman's if I get my 424 done this spring. They lasted fine but one side has a filled crack and the other filled where the positive cable shorted out, they are 10 years old and ceramic coated. Like any headers the bolts at the heads need retightened occasionally. Only the Copper or Aluminum collector gaskets lasted any time.
Old Nov 24, 2017 | 05:05 PM
AZ520's Avatar
Thumbs down
Headers suck on any car, leaks, heat and everything else.
Old Nov 24, 2017 | 05:55 PM
Ceramic coating, Copper or Aluminum gaskets and thick flanges go a long way to sealing properly with only occasional retightening. Stock manifolds for the SBO are restrictive.
Old Nov 24, 2017 | 11:59 PM
Inline's Avatar
Im also mildly interested about this topic..
Ive been wondering over and over again, are long tubes worth the effort on street-driven car versus short-tubes. Sure, youre giving up on power, but does the amount really matter?
All the hassle, getting them installed, maybe banging some pipes so they would clear something, with bad luck lesser ground clearance etc.. Just dont know.
Having exactly same thoughts as Mr.Nick about the subject.
Old Nov 25, 2017 | 03:25 AM
AZ520's Avatar
I would recommend remflex gaskets if you mess with headers!
Old Nov 25, 2017 | 08:07 PM
Sanderson headers just need RTV around the ports, good to know about the Reflex gaskets for the other headers.
Old Nov 25, 2017 | 10:43 PM
76olds's Avatar
Hookers under Hood
I'm posting for my Dads car here,
My Dad has headman short ceramic coated headers with remflex gaskets on his 1976 350, no complaints in 4 years so far. Haven't leaked before or after the first heat cycle torque tighten. Hit the loud pedal and feel a spike of decent performance coming from them through seat of my pants dyno.
I have driven his car a few times over the years , I'm here posting since he hasn't felt well in the past few weeks.
I hope I'm welcome here to post here on the site.
Old Feb 24, 2018 | 09:39 PM
Hoffman2099's Avatar
Have you put them on your car? If so, do you like them?
Carl, uk
Mar 13, 2014 05:43 AM
VinMichael
May 30, 2013 10:54 AM
yeahbuddy
Oct 27, 2011 05:30 AM
Dave Siltman
Feb 16, 2011 05:59 PM
geckonz08
Aug 21, 2008 07:58 PM
