84 Olds 307 exhaust manifold interchange
Old Yesterday | 04:53 PM
Coco 84's Avatar
Hello, I am looking to replace my factory exhaust manifolds with smog air pump lines to a none emissions exhaust manifold. The lines are rusty and keeping leaking exhaust and its getting old with the ticking it makes. Looking for a permanent solution to the issue.. Will any Olds 350, 403 manifolds from the 1970s fit the 1984 307 without changing the factory exhaust? I am guessing the manifolds are the same,(correct me if I'm wrong), but will the factory exhaust pipes bolt up to it? Cant find any info about it. Thank you in advance for any info on this.
Old Yesterday | 06:29 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The mid 70's and up are the same outlet angle with any Olds V8 that had a factory catalytic converter. The lines go in the head and goes to the cat, does it not, it has been over 20 years since I saw one of these in the wild. You will be lacking the O2 sensor port as well.
Old Today | 06:43 AM
First of all, the A.I.R. pipes screw into the HEADS, not the manifolds (this isn't a Chebby), so swapping manifolds doesn't change that. As for what fits, your 1984 307 has 5A heads, which have the same exhaust ports as on pretty much any earlier SBO. The manifolds interchange, and frankly in some cases they are even the same part numbers. The 1985-90 roller cam 307s with the 7A heads have the smaller exhaust ports with the stainless tubular manifolds.
Buick77
Oct 17, 2025 01:01 PM
Lenny39
Oct 12, 2022 05:50 PM
Mred355
Dec 27, 2013 05:23 AM
reesejames
Jan 20, 2011 08:24 PM
ELECMAN
Mar 15, 2010 10:50 AM
