#8 Heads on a 70' Olds 350
Old Aug 8, 2009 | 12:16 PM
nickd's Avatar
Are #8 good heads for a 70' Olds 350. How are #8's compared to the rest?
Old Aug 8, 2009 | 12:28 PM
captjim's Avatar
It is claimed that the #8 heads don't flow as well as the earlier 350 heads. But, the main issue IMO is that the #8 heads have a huge chamber and will significantly lower the compression ratio when bolted on an engine with stock pistons.
Old Aug 8, 2009 | 12:37 PM
gearheads78's Avatar
car guy
If you want to drop the compression back down and still have hardened seats I have some early 7A head cores I will sell cheap.
Old Aug 8, 2009 | 12:53 PM
nickd's Avatar
No thanks gearhead but thanks for the offer. I just wanted to know as I had this motor in my car before i cooked the bearings. This combo seemed to run very nice getting tire spin hitting second gear in a 4000lb car. I think I'm just going to put a set of bearings in it and put it back together as a cruising motor.Thanks
lunaboy
Sep 24, 2018 10:15 AM
QS442
Jun 12, 2014 06:47 PM
gearheads78
Nov 10, 2009 09:31 PM
dharlett
Sep 23, 2009 03:30 PM
shaks 442 clone
Oct 18, 2008 09:41 AM
