76 Cutlass 350 choke tubes
Old Nov 6, 2023 | 05:55 PM
getmygoat's Avatar
Hey all,
Just wondering if anyone knows if the choke tubes for 70 cutlass will also fit 76? Inline tube makes replacement tubes for the 70-72, but they don't list as compatible with 76. Seems like it would work from the pic, but does anyone know? My car has electric conversion and I'd like to remove that and go back to original config.
1969 70 71 72 442 Cutlass W-31 350 Intake Manifold To Carburetor Choke Tubes Oem | eBay
Thanks!
Old Nov 6, 2023 | 08:26 PM
I don’t know for certain, but if they fit the 403 engine, then I suspect they would fit your ‘76 350 as well.
Old Nov 7, 2023 | 06:23 AM
getmygoat's Avatar
Contrasting these two pics - one is a 76 unrestored original, the second a 70 cutlass restored, choke fitting seems identical? and I assume the intakes are the same also?
Old Nov 7, 2023 | 12:25 PM
I am no expert on this, but it seems for a small block, the tube from the intake to the choke should be the same. It's the fresh air intake tube from the back of the carb to the intake that is different depending upon where it connects to the carb.
ELECMAN
Mar 12, 2024 11:45 AM
72 Post
Jun 29, 2023 05:52 PM
Chuxter
Apr 8, 2023 11:28 AM
oldolds88
Feb 5, 2017 07:38 PM
Pfiffle
Dec 14, 2016 03:39 PM
