72 350 rocket 2 barrel timing issue
Old Oct 2, 2016 | 02:05 PM
72delta88's Avatar
I have a 72 delta 88 350 rocket I just converted to msd hei from points its getting spark fuel ect but still wont run I had the timing mark to 0 and it still wont run I drove it 80 miles home before the points crapped out it sat for 2 years and may have a mild cam but the car is original over wise
Old Oct 2, 2016 | 03:56 PM
Welcome. First, what do you mean by "the points crapped out" and did you change the whole distributor as a result? Are you SURE the points were the problem?
If so, chances are you have the distributor installed 180 degrees out of phase.
Old Oct 2, 2016 | 04:07 PM
72delta88's Avatar
the points were burnt to a crisp and the dizzy was stuck in the block it had a ring of corrosion around the basre it now has abrand new hei distributor controlled by a msd street fire
Old Oct 2, 2016 | 04:09 PM
72delta88's Avatar
it also has new plugs, plug wires the box is getting 12v
Old Oct 2, 2016 | 04:22 PM
So I'll ask again, are you sure you aren't 180 out? Have you tried it without the MSD box?
Old Oct 2, 2016 | 05:09 PM
I'll add, is it wired for full battery voltage? You understand you can't use your original timing settings? Which distributor did you install? I'm assuming that your using the MSD 5520 box?
Old Oct 2, 2016 | 05:34 PM
72delta88's Avatar
it was 180 out I corrected that and it tried to start the battery is so low even jumping it didn't work I tried it without the msd5520 and it still wouldn't start its the assault hei that's like 53$ on ebay yes its wired for full 12v at the battery and at the key as per msd manual
Old Oct 2, 2016 | 05:43 PM
72delta88's Avatar
nice pic my 72 is sapphire blue with a blue top
Old Oct 2, 2016 | 05:51 PM
Run a jumpre wire directly from the positive battery cable to the HEI batt terminal and start the engine with the key. To turn off you need to disconnect the wire and then turn the key off. Set your initial timing at 16* BTDC and fine tune from there. With a stock or relatively stock engine the box really is overkill.
Old Oct 2, 2016 | 05:55 PM
72delta88's Avatar
tried it ive gotta get the battery charged tomorrow its not gonna stay stock for long that's y I wanted the box its getting heads cam intake and headers over the next 4 months and I wanted the rev limiter
Old Oct 2, 2016 | 05:59 PM
72delta88's Avatar
the battery is at 9 volts so its dead it wont even kick the starter
Old Oct 2, 2016 | 06:40 PM
Let us know how it goes.
Old Oct 2, 2016 | 06:43 PM
72delta88's Avatar
I was a chevy guy before I bought the delta so its kinda new for me any pointers
Old Oct 2, 2016 | 06:46 PM
The only real difference is the rotor moves CCW. Tuning principles are the same.
Old Oct 2, 2016 | 06:48 PM
72delta88's Avatar
is the # 1 terminal on the did at the front or back I know the cylinder is at the front drivers
Old Oct 2, 2016 | 06:59 PM
Most use this for an HEI:
And this for points:
To be honest the distributor doesn't care where #1 is wired as long as the rotor points to it at the right time and the firing order is wired correctly.
Old Oct 2, 2016 | 07:06 PM
72delta88's Avatar
thanks so much I tried the points 1 it didn't work for the hei I used the hei pattern and that's when it tried to start
Old Oct 2, 2016 | 07:10 PM
The different #1 positions between points and HEI is because of the premade wire lengths.
Old Oct 2, 2016 | 07:16 PM
72delta88's Avatar
I'm gonna try it again in the am I got the box issue fixed I think it was 180 out and 2 terminals off
Old Oct 3, 2016 | 05:57 PM
72delta88's Avatar
got it running today then the water pump and thermostat and the carb went bad
Old Oct 3, 2016 | 06:37 PM
Eventually you'll run out of broken things to fix.
Old Oct 3, 2016 | 06:46 PM
72delta88's Avatar
the carb was gushing gas after shut off its roached and it was 75 degrees out and the car was running at 225 and climbing and it got gas in the oil and the temp was in stop and go traffic
Old Oct 4, 2016 | 06:29 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
75 degrees out, how did it even run? I once had my Olds about 20 degrees advanced after swapping distributors, noticed it was a hard restart. Probably the needle and seat stuck from old shitty gas.
Old Oct 4, 2016 | 06:39 AM
I think he meant the temperature was 75* out...
Old Oct 4, 2016 | 06:46 AM
The carb. "gushing gas" means that the float is stuck.
Nothing to do with roaches.
You may want to rebuild it.
225° in stop and go traffic could be a stuck thermostat (since we know things are stuck), or an obstruction (or blocked radiator), or a bad fan clutch, or a missing fan shroud.
Fuel in the oil is because of the stuck float.
You need to go through this engine one thing at a time. (And if the points were a problem, you'd have saved yourself a few days by just replacing them, rather than installing a whole new distributor and ignition system).
Old Oct 4, 2016 | 07:43 AM
72delta88's Avatar
i had a engine builder whos friends with my dad go through it the carb is gone the body and base were corroded and warped the radiator is clear I'm thinking its the thermostat or fan clutch no one around here had the right set of points and i prefer the msd hei for reliability even after a good cleaning the carb looked like the bottom of the il river and the distributor was wore out ( the carb water pump dizzy fan clutch and thermostat are original
Old Oct 4, 2016 | 07:46 AM
72delta88's Avatar
the temp out was 75
we cleaned the carb the day i bought the car turns out the body and base were warped
Old Oct 4, 2016 | 07:58 AM
Which also probably means your timing chain is original too. MAW do it since your only a few bolts away when changing the water pump.
Old Oct 4, 2016 | 08:03 AM
72delta88's Avatar
the timing chain is where I'm unsure because we found 2 prevous owners priar to the one who sold it to me and owner 2 put a comp 280 cam in in 09
Old Oct 4, 2016 | 08:05 AM
Forgot you mentioned that earlier in the thread. Then I would suspect the water pump was replaced also.
Old Oct 4, 2016 | 08:10 AM
  #31
72delta88's Avatar
I'm going to start with the thermostat and fan clutch the carb going on it is a holley 4 barrel 600 cfm vac secondary on a 4-2 adaptor till I buy an intake it idles well at 750 and drops to 600 in gear
Old Oct 15, 2016 | 04:34 PM
  #32
72delta88's Avatar
thanks everyone for the help ive got the car running perfect I changed the radiator and carb now it idles at 975 in park 750 in gear with the timing at 8 degrees before tdc it will chirp the tires when I mat it it just wont burn out when its power braked but it runs amazing and temp is 185 in stop and go traffic
Old Oct 15, 2016 | 05:43 PM
  #33
Great!
Old Oct 15, 2016 | 05:51 PM
  #34
72delta88's Avatar
I'm putting it up for sale for 7500 its numbers matching 2 door royale coupe with almost no rust and 105000 on it
Beau Dirt
Dec 27, 2021 03:02 PM
tcolt
Mar 16, 2017 09:58 PM
63 F85 Cutlass
Feb 8, 2015 03:20 PM
66ninetyeightls
Mar 28, 2010 07:40 AM
442scotty
May 13, 2009 05:42 PM
