70' 350 Removal Help
Old Dec 10, 2016 | 09:03 AM
tgilligan's Avatar
Hey Guys,
Need some advice as to steps needed to pull the engine from my 70' CS. I did alot of top half work but with doing additional projects I ended up taking most of the front end apart and now might as well keep going to clean it up and check things out. Never attempted this before so looking for some advice. After lines and wires at disconnected, is it motor mounts and disconnect from tranny or is it more involved? It got to this point as I was looking to replace the oil pan and gasket but know there's a clearance issue so why not pull it since front end is basically taken apart already, attached a pic of how it sits currently. Thanks in advance for any help for a novice weekend mechanic.
Old Dec 10, 2016 | 12:59 PM
Search is your friend:
"Pulling the Motor"
Old Dec 10, 2016 | 01:55 PM
tgilligan's Avatar
"Pulling the Motor"
I was anticipating that! Thanks Eric. As it is my normal to make everything more complicated, I kept putting too much in the search criteria and not getting the results I wanted. Thanks for the help.
Old Dec 10, 2016 | 02:10 PM
Do not break the A/C lines, just unbolt the compressor from the engine as a unit with the lines attached, swing it out of the way and tie it off to keep from damaging it. Since you have the whole nose off the car it will be very easy to pull and reinstall the engine.
Old Dec 10, 2016 | 04:25 PM
Olds442redberet's Avatar
It's not to hard. Just take your time, be patient, have a drink, and plan on spending a few hours taking it out. The first time is always a bear.
My biggest unplanned hang up is always when I forget to remove the starter and oil filter. They always seem to get hung up on the engine mount pads.
Removing the radiator support also makes things much easier. And you've already done that.
Old Dec 10, 2016 | 04:44 PM
And the throttle cable. Don't forget the throttle cable.
RALLYE-DEBBIE350
Jul 21, 2024 09:26 AM
blunce
Jul 23, 2014 07:41 PM
dharlett
Sep 23, 2009 03:30 PM
CUTLASS FREAK
Brakes/Hydraulic Systems
Sep 17, 2007 08:57 AM
CUTLASS FREAK
Drivetrain/Differentials
May 14, 2007 08:05 AM
