67 330 intake gaskets
Old May 13, 2016 | 10:10 AM
Roger60's Avatar
Noticed the difference in the intake manifold gaskets as one has openings for the exhaust crossovers and the other doesn't. Early 67 so no large valley pan. I know exhaust blocks have been used to fight vapor lock. Heat riser for choke depends on hot air. So what are the pros and cons? Thanks
Old May 14, 2016 | 05:29 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
There are two Turkey trays, early and late, the cross over is larger on later heads. There is just the side rails style in steel from Feel Pro for your motor. Plugs come loose and a piece of stainless steel or the heads cross overs filled are needed with gaskets with no cross over cut out. Otherwise they just burn through the fiber gaskets.
cjsdad
Jun 27, 2015 02:03 AM
don_69sbo
Sep 5, 2011 01:35 PM
jag1886
Jan 16, 2011 08:41 AM
rtpassini
Nov 20, 2010 05:58 AM
Kidcutty
Mar 25, 2010 09:29 PM
