67 330 Hi or Low Comp ?
Old Mar 6, 2021 | 08:35 AM
sldwys's Avatar
How to determine if engine is true high compression or low compression. 67 olds cutlass supreme convertible. Member on here is selling and neither of us are sure what engine.
Any help would be appreciated. I want the engine if it checks out.
Pic of engine.
Old Mar 6, 2021 | 08:38 AM
The cowl tag unfortunately won't tell you anything about the engine. If the heads have not been touched, the engine unit number stamped on the front of the passenger side head will indicate high or low compression. The foolproof way is to use an inspection camera in one of the spark plug holes to look at the size of the piston dish.
Old Mar 6, 2021 | 08:43 AM
sldwys's Avatar
I gotcha. Can you atleast confirm from the cowl plate it’s a cutlass supreme?
The engine unit number will look like the lower photo. A 1967 330 engine unit number will start with "W", followed by six digits. A low compression 330 will have no suffix. A high compression 330 will have a "G" suffix. While unlikely on a US car, an "E" or "H" suffix would indicate a low compression export motor.
Old Mar 6, 2021 | 08:53 AM
33867 is a Cutlass Supreme convertible.
Trim 980-C is a black vinyl bench seat with arm rest
Paint T-2 is Cameo Ivory (T) lower body color with Black (2) convertible top
ACC Codes
Group 1
E = tinted glass
X = power windows
Group 2
E = firewall piercing for A/C
Group 4
F = outside remote mirror
Old Mar 6, 2021 | 09:44 AM
Sugar Bear's Avatar
ID the pistons as suggested or test compression on a cylinder. A forum member will know the pressure expected for LC vs. HC. If it is high compression # you know it is an HC engine but if a low # it could be due to leakage.
Does it have a Premium Fuel Only gas cap?
That is another indicator of HC; but, obviously it could have been changed.
ID the pistons if you can, it is the most conclusive way.
Good luck!!!
Old Mar 6, 2021 | 01:09 PM
Oldsmaniac's Avatar
If original air cleaner and paint its a low compression engine. Black was used on the air cleaners if it was a LC engine. The HC engines got the orange air cleaner paint.
Old Mar 17, 2021 | 12:14 PM
brianbeez67's Avatar
67 Compression
Here is a pic of the pistons, to me would be hard to tell the diff if not in your hand?
Old Mar 17, 2021 | 12:22 PM
HC has a dish about 1/16" deep. LC is about 1/4" deep. It's pretty obvious.
Old Mar 17, 2021 | 12:28 PM
Old Mar 17, 2021 | 01:56 PM
I've always believed that if it came with a 4v it was hi comp and a 2v was low.
Old Mar 17, 2021 | 02:05 PM
Unfortunately that is not correct for the 1967 330 motors.
Old Mar 17, 2021 | 02:14 PM
sldwys's Avatar
Thanks for all the info. I never got the engine and wasn’t driving 4 hours since it was assumed to be low compression.
brianbeez67
Feb 9, 2021 09:48 AM
Freebeer
Aug 1, 2012 11:47 AM
MudEye
Dec 15, 2011 07:27 PM
MudEye
Dec 15, 2011 05:34 PM
67442nut
Nov 11, 2011 09:08 PM
