67 330 engine pull
67 330 engine pull
Pulling the 330 out next week have the lift already, want to know what you guys think is the best/safest way to pull it. Transmission will be dropped out later. Carb plate? Chain on heads?
Grade 8 bolts aren't the worst idea either, had a grade 5 bolt break, good thing the motor was a foot in the air. The leveler with the hood removed is best method unless you don't have help to remove the hood. Remember to support the front of the trans with either a floor jack or something like a ratchet strap and a long bar if the car needs to be moved.
Always tighten the bolt against the chain to avoid bending loads. If necessary, use spacers between the chain and the head of the bolt to ensure the chain is clamped against the head. I've used sockets for that occasionally. Grade 8 is preferred, but Grade 5 will be fine so long as you aren't bending it. Gr 5 bolts are 75 KSI shear ultimate, Gr 8 are 91 KSI. For a 3/8" diameter bolt, that's about 8,000 lbs in shear for Gr 5 and 10,000 lbs for Gr 8. A single Gr 5 bolt could lift your whole car with margin if you ensured it was only loaded in shear. Once you start bending the bolt, however, things go downhill in a hurry.
First engine pull ever and by myself at that, the whole front end is off and will stay off for engine return. Trans will just roll out the front. That’s my novice plan. Hope all goes smooth. Thanks guys
That makes it even easier to pull and reinstall both at the same time while still attached to each other..
If you will need to move the car around later remove both the engine and trans at the same time, unbolt the torque converter from the flexplate before removing the assembly. It's doable later but easier now. Whichever way you proceed, after unbolting the converter push it back into the transmission and note the gap between the flex plate and the converter. Upon reinstall you need the same gap or the converter isn't seated and it will damage the front transmission pump when bolting the engine and transmission back together.
Good luck!!!
Good luck!!!
Good luck!!!
Good luck!!!
That's what he said - that it's much easier to unbolt it with the drivetrain in the car than when 800 lbs of engine and trans are swinging above your head hanging from the engine hoist.
Hope this helps and good luck!!!
djsoldzparrts
November 11th, 2008 06:46 AM
