64 330 waterpump question
Old Jan 5, 2010 | 06:19 PM
Iragh's Avatar
ok i have a 1964 cutlass with the 330 in it. the water pump has the radiator outlet on the driver side. they no longer make the molded hose for it so im trying to figure out how to switch to a water pump from a later year that has the outlet on the passenger side ive seen articles on doing the switch but cant seem to find them can anyone point me in the right direction please and thank you
Old Jan 5, 2010 | 08:03 PM
Mongoose's Avatar
Short of using a flex hose, it seems like not only would you need to change out the water pump, but you'd also need to change out the radiator for one with a passenger side bottom outlet.
Old Jan 5, 2010 | 08:04 PM
gearheads78's Avatar
car guy
Not 100% sure but I think you need to change out to 65 type acc brackets too.
Old Jan 5, 2010 | 09:31 PM
f-85's Avatar
Just use the flex hose thats what i originally did.
If you switch the pump you will have to switch the radiator. All your brackets will still line up if you use the 65 5.1" waterpump. Thats what i did later after i poked a hole in my radiator and went to an aluminum one.
If you have any other questions just ask.
Josh
Old Jan 6, 2010 | 12:04 AM
64Rocket's Avatar
If you have a real auto parts store around, you can send your pump out and have it rebuilt. That is what i did.
If you change to the '65 and later style. You will have to change the radiator lower outlet to the other side. the hose for that is still available.
Gene
Old Jan 6, 2010 | 07:44 AM
It's even more than that. Besides changing the accessory brackets, you need to change the timing tab and balancer. As noted, either rebuild your original pump or use a flex hose. The 64 pumps show up on ebay frequently.
Old Jan 6, 2010 | 08:46 AM
f-85's Avatar
You dont have to change the brackets if you use the 65 5.1" water pump.
Here is my setup. 468 Olds, aluminum radiator, 65 5.1" water pump, all original 64 330 brackets.
I forgot about the timing tab, yes you have to swap to a drivers side timing tab. I have extras if you need one.
Old Jan 6, 2010 | 04:49 PM
Iragh's Avatar
i cant seem to make a flex hose fit right i have a local radiator shop that can switch the ports to the oppisite sides. thats what im going to do thanks for the info everybody
Old Jan 17, 2010 | 02:52 AM
Wasted's Avatar
The flex hose is hard to get on, I always end up swearing my head off the whole time it takes me to muscle it on If its a new hose get ready to make up some new words.
greg pettit
Jun 4, 2013 06:55 PM
rustycragars
Nov 18, 2009 01:21 AM
MN71W30
Aug 13, 2009 04:51 AM
montvaleplace
May 29, 2009 06:33 AM
wolfman98
Feb 10, 2009 05:16 PM
