403 stroker crank
Old Feb 14, 2020 | 02:38 AM
dragline's Avatar
403 stroker crank
Is there a stroker crank available for the 403? Has anyone done a big cube 403? Thanks
Old Feb 14, 2020 | 03:19 AM
svnt442's Avatar
https://classicoldsmobile.com/forums...-478-a-141721/
Old Feb 16, 2020 | 12:52 AM
dragline's Avatar
Can the crankshaft be purchased separately?
Old Feb 16, 2020 | 02:33 AM
svnt442's Avatar
Contact Mark. It's his crankshaft design.
https://classicoldsmobile.com/forums...utlassefi.html
Old Feb 16, 2020 | 06:28 PM
olds403's Avatar
Get in line....most of us are putting them in 350’s. Wasn’t going to risk a 403 knowing that had to girdle/fill the block. Nearly went DX but machining is too much money. A 4.185/4.25 small block with 2.5 mains would be golden.
Old Feb 17, 2020 | 07:53 AM
oldsmobiledave's Avatar
is there currently a source for a 4.25" SBO stroker crank or are you saying that 4.25" is what you see as optimal?
Old Feb 18, 2020 | 08:00 PM
olds403's Avatar
My comment was on the bore size of the block.
Old Feb 20, 2020 | 10:14 AM
My bad. I thought your 4.185 / 4.25 was a bore and stroke combination when you meant it as a bore range.
Old Feb 21, 2020 | 06:31 AM
oddball's Avatar
I suspect 4.25" stroke would be damn near impossible with the SBO short deck.
It appears most D/DX blocks can go to 4.185 without breaking a sweat. 4.250 bore is the upper limit of the good ones. But, all depends on what you consider acceptable wall thickness. The D block I have would have a single non-thrust thin spot at 0.140" @ 4.250".
Old Apr 21, 2022 | 07:13 PM
bccan's Avatar
Dammit Mark - You keep making me seriously consider a bigger cam and thinner head gaskets, then why not open up those head ports, and then that RPM in my attic should get opened up, then can I get my Qjet to keep up, and, and, and. I don’t wanna spend that money and do that much work but you keep on hanging out a bug light, it just keeps drawing me closer…
Old Apr 22, 2022 | 05:14 AM
cutlassefi's Avatar
Sorry!!😎
cdrod
Jan 1, 2019 11:12 AM
halfmoontrail
May 31, 2013 05:41 AM
80_cutlass
Sep 14, 2010 09:21 PM
dman0712
Jun 18, 2010 07:41 AM
sethj78
Aug 20, 2008 06:26 AM
