403 head alignnment dowels with 350 heads
Old Aug 3, 2013 | 04:33 PM
tomngary's Avatar
Anyone one know what the exact size the larger alignment
dowel size needs to be drilled out to for fitting the
350 heads on a 403. Most posts just says that one
dowel hole on each head needs to opened up "a little".
Also, has anyone done this at home with a drill or
should I leave this to a machine shop?
As this part was something I completely forgot about
when I had the heads done, I hate to slog the head back
to the shop if I dont have to .
Thanks,
Gary
Old Aug 3, 2013 | 05:26 PM
1970-W30's Avatar
I don't recall exactly but I'm pretty sure it goes from 1/4 to 5/16 inch. Did it at home with a cordless drill. Use a drill gauge or calipers to measure the locating dowel on the block to be positive and don't drill any deeper then necessary on the head......
Old Aug 3, 2013 | 05:55 PM
tomngary's Avatar
Thanks for the reply.
I think I will give it a shot.
Gary
Old Aug 4, 2013 | 05:16 PM
tomngary's Avatar
update:
Just finished drilling out the alignment dowel holes.
Used several sizes of bits to work up to the 5/16 and
some cutting oil. Worked like a charm.
Thanks for the encouragement!!
Gary
88hurstolds
Jan 20, 2020 11:39 AM
J-(Chicago)
Feb 26, 2014 09:14 AM
boondocker
Jun 18, 2011 12:29 PM
Oldsmaniac
Nov 1, 2010 06:37 PM
DarkStar
Oct 21, 2009 07:35 AM
