403 Block with 350 crank?
Old Dec 28, 2018 | 05:35 PM
cdrod's Avatar
Rodney
Can a 350 crank be used in a 403 engine build using the stock 403 rods & pistons? I know the 350 crank will physically fit in the 403 block, but will it need to be rebalanced for the heavier 403 pistons?
Old Dec 28, 2018 | 06:18 PM
cutlassefi's Avatar
Anytime you change any of the pieces in the rotating assembly it'll need to be balanced.
Old Dec 29, 2018 | 07:06 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Follow Mark's advice. I ran a 307 crank in a 403, lasted quite a few miles till I revved it to 5500, then spun rod bearings.
Old Dec 31, 2018 | 05:17 PM
BillK's Avatar
Yes and it will most likely be an expensive balance job because you will have to add weight to the crankshaft.
Old Dec 31, 2018 | 07:51 PM
Kennybill's Avatar
Is something wrong with the original 403 crankshaft? Imo, the 350 crankshaft isn't an upgrade. The only upgrade would be a 330 forged crankshaft that would require the 330 harmonic balancer and 330/early 400 flexplate.
Old Jan 1, 2019 | 06:11 AM
cutlassefi's Avatar
Originally Posted by Kennybill
Is something wrong with the original 403 crankshaft? Imo, the 350 crankshaft isn't an upgrade. The only upgrade would be a 330 forged crankshaft.
Hmmmm not true. The 403 crank is the worst of the bunch, a true cast crank that’s quite spindly as well. Even a stock N 350 crank would be an upgrade.
Old Jan 1, 2019 | 10:56 AM
cdrod's Avatar
Rodney
Kenny:
I bought 2 403 blocks several years back when I was still contemplating the my engine options. Both blocks are std bore and came with 2 complete sets of stock rods & pistons, one very rusty 403 crank and a good condition 350 N crank. The 403 crank had been left in the weather and was too rusty to save so I sold it to a guy that builds furniture with engine parts. He planned to sand blast the rusty crank and use it to make an end table for a TransAm guy. I really need the space so I'm trying to sell the rest of these parts. I didn't want to give out bad info on using the 350 crank in the 403 block so I checked in with the CO crowd. I wonder if you built the 403 with lighter rods and pistons would you still need to add metal to the crank to get it to balance?
Old Jan 1, 2019 | 11:12 AM
cutlassefi's Avatar
Yeah a little normally. That EFI’d 403 I just posted on here had lighter rods and pistons and only needed 3 slugs, 2 1”, and 1 1/2”, and that was with a 330 crank. If it were an N crank it normally only needs 1 slug on each end.
Using the different rods and pistons saved over 300gr on the bobweight. Pretty significant I’d say.
Oldsragger
Feb 9, 2018 08:38 PM
TBT_DK
Feb 22, 2017 06:36 PM
80_cutlass
Sep 14, 2010 09:21 PM
sethj78
Aug 20, 2008 06:26 AM
falconsfan
Jun 1, 2007 08:05 PM
