4 or 5 speed for 66
Old Jul 13, 2015 | 03:02 PM
shapcars's Avatar
4 or 5 speed for 66
Hi all, I am new to the forum.
I have a 1966 Cutlass convertible with a factory 3 speed, A/C, PS,PB. The hurst shifter rattles very badly. To fix it, I have been told the tranny must come out. When I look underneat, it says FORD (?). My question is should I use the opportunity to upgrade to an M20? I am open to suggestions. Want to spin less RPMs on the freeways.
Old Jul 13, 2015 | 03:39 PM
Yes, Olds used the Ford 3 speeds. I believe the final drive ratio is the same on 3 and 4 speeds, so to get less RPMs you would need to go to a 5 speed.
Old Jul 13, 2015 | 08:13 PM
shapcars's Avatar
4 or 5 speed for 66
Given it is a 3 speed Ford box, would a Ford (Borg Warner) OD be an option?
Old Jul 14, 2015 | 08:16 AM
GM used the toploader three speed from 1965-69 as the HD three speed floor shift option. This trans uses the Ford bolt pattern to the bellhousing but has a unique GM input shaft. Other Ford transmissions do not bolt in because of this.
Your factory bellhousing has both the Ford and Muncie bolt patterns. A Muncie swap is easy. As noted, you need to determine exactly what you want out of a trans swap. ALL GM 3spd and 4spd transmissions have a 1:1 final gear, so only an OD trans will change that. Also, note that the 3spd first gear is not too far from first in the Muncie. Changing to a four speed will not appreciably change off-the-line acceleration, either.
Finally, why does the trans have to come out for a shifter problem? The shifter can be removed separately. If the vibration is really a symptom of a different problem, however, that may require trans removal.
Old Jul 14, 2015 | 09:45 AM
D. Yaros's Avatar
My reaction was similar to Joe P's in terms of trans removal to solve shifter rattle problem. Did not make sense to me to have to go to that extreme to diagnose/resolve rattle problem?
Old Jul 14, 2015 | 09:47 AM
dc2x4drvr's Avatar
You'll need an overdrive trans to lower cruising rpm.
Old Jul 14, 2015 | 11:26 AM
young olds's Avatar
If you want to stay 3 speed you can do a Saginaw with Borg Warner overdrive
Old Jul 17, 2015 | 11:34 AM
shapcars's Avatar
4 or 5 speed for 66
Thanks for all of the feedback. I will be searching out prices of each option and instillations costs. Stay tuned.
s i 442
Jul 14, 2013 04:41 PM
halfmoontrail
Jun 22, 2013 09:41 AM
Big Mikey
Mar 27, 2013 06:51 AM
joynerz
Jul 25, 2012 07:34 AM
ilde
Feb 7, 2008 10:21 AM
