3rd gear bogs at WOT...advice to troubleshoot please??
here is the chart from RobbMC for their olds 550HP pump...the first chart is free flow, the 2nd chart is @ 4.5psi:
http://www.robbmcperformance.com/products/olds550.html
you can see it pumps well over 60GPH @ 4000 & 5000 RPM (4.5psi)...so this pump, my new 3/8 sending unit, pressure regulator and a new fuel filter should supply plenty of fuel for my current & future needs.
I was just reading about vapor lock, sounds like that could be my problem right there. Which is still basically lack of fuel delivery (due to gas pockets in the line) to the carb causing the bowl to drain under high throttle conditions. although it says usually vapor lock happens at idle and low speeds, so maybe not.
2 x ( flywheel HP x .5 / 6) = required GPH
my application -> 2 x ( 320HP x .5 / 6) = 53.33 GPH @ 6psi
it also noted that most fuel pumps advertise their GPH capabilities at 0 psi. so a pump that advertises 80gph will actually pump less as the fuel pressure increases. as pressure increases, flow decreases....so we need to figure out what the pump needs to deliver at the psi your system will run at. mechanical pumps will usually increase pressure at RPM's increase. since i have an eddy performer, my fuel system should deliver at 6psi. so i need a pump which will deliver at least 53.33 GPH @ 6psi. now....if i do the heads and cam this winter and get up to let's say 400HP at the flywheel i'll need at least 66.66GPH. so i'm thinking my fuel system is about to get a complete reconstruction for higher volume delivery.
What i'm getting at is, if I'm having a similar problem with 100hp less, and a similar fuel pump, could there be another problem? Could it be a short coming in the carb?
Just for the halibut, change the 6-8-10 inches of rubber fuel line between the steel line and the pump.
I've heard more than 1 story of them collapsing internally or 'pinholes' that'll suck air under high flow situations.
I'm gonna see what this guy says about it this weekend. He's gonna time it correctly if it isn't already, fill the tank with gas, take it for a ride and put it to the floor to see what happens when it hits third. If he concludes it's fuel delivery issues, then I'll see what he suggests as a remedy. I've also been thinking, if I end up having him do the heads and cam, I'm gonna need to upgrade my fuel system anyway.
As far as the vapor lock...it was just something I thought may be the problem, not quite familiar with it honestly. In my research, it was something I came across.
I'm pretty sure I have a 3/8" hard line front to back already (I'll have to check). Also, the sending unit I'm going to install is a vapor return style unit. So if I went with the RobbMC pump (with return option) and a regulator I could incorporate a return line...then I should not have to worry about fuel supply anymore, up to 550hp anyway.
You are getting into the term I like to call mental ************! It's what happens when you get all wrapped up in assumptions, what if's, and technical BS. Your engine nor your powertrain is anything special. A common off the shelf fuel pump is fine your application.
Why don't you wait until your friend does a bit of trouble shooting and go from there?
i think it ONLY MAKES SENSE that i may need a major fuel system overhaul, not only because of my engines CURRENT demand, but because of what it's FUTURE demand will be as well. are you saying it wouldn't be a good idea to put in a new clean gas tank?? fresh sending unit with clean sock??? high volume pump?? bigger lines??
last i checked, my decision to ********** involves nobody but myself, not sure why you would be bothered by it. my plans for this car is MORE POWER TO THE GROUND!!! i'm not just gonna leave the car as is and drive it for the rest of my life.....i'm constantly upgrading with the funds that are available to me. my engine and drivetrain may not be "anything special" but it's 10x better than it was when i got the car and will continue to get better. it may not be anything special to you, considering your sitting on a 468ci, but it's pretty special to me. if i want a top of the line fuel delivery system so i don't have to worry about it, then that's what i'll have. you make it seem like i shouldn't replace my sending unit, or that i shouldn't get a high volume pump...but they sure as hell won't hurt. if i had the "just leave everything as it is" mentality, then i wouldn't have the car i have today, neither would you. hell, i'd even consider upgrading the fuel system even if i didn't have a problem, LOL.
here are a few pics of my friends 69 442, 468ci...motor alone 510HP, w/ NOS 760HP:
he recently installed a ram air induction system:
still could be the float level, Tony got his ebrock new and his floats were messed up outta the box.
@ JPC I have a 600 ebrock on my 72 350 w no issues goes from 0 mph right to ~5k rpms in first and second and keeps going in third till I let off It. IDT its something inherently wrong w the carb...
Thats nice ride your friend has there, and yes, your car has come a long way! However, just to throw money and parts at things that won't neccessarily improve your setup is not what most of us do. Your problem may or may not be a function of your fuel system. Your fuel system is probably more than adaquate for your setup IF it's functioning properly.
I meant by the term nothing special, as in not really super high HP. Btw, my 468 runs off a stock pump, original lines except rubber parts, and original tank and internals.
I meant what I said as encouragment, not to degrade. My point in all this is I hate to speculate, I troubleshoot and repair/ or improve as required!
i was under the impression that a fuel pump either works or it doesn't, but apparantly they can get tired/worn and not be fully funtional. so i am thinking that it may be the case with my pump, as it is about 6-8 years old. i forgot about this, but last year i started her up one day and while it was warming up i smelled serious fuel, looked under the car and saw some fuel leaking onto the driveway. so i got down on the ground to check it out and it was leaking from the gasket on the fuel pump itself. i popped the cover off the fuel pump and replaced the gasket, as it was all dried up and cracking. i made the new gasket out of some thin rubber material i had kicking around. so now i wonder, maybe the pump doesn't have a good enough seal for high fuel demand situations.
I am a bit lost here..
and looking to get educated, ok
the Poster says his car goes to 5K rpm in first no issues, ok less load on the motor etc because of the gearing, fuel, timing etc are fine, shifts well, does the same thing goes to 5K in second no issues, I would think the motor has a little LESS load as it is moving already, ok shifts to third and then there are issues? ok so what is the difference of the motor going to 5 K, gearing , but there is more or less load on the motor? I mean there is inertia etc right? the motor is making the same horsepower, going to the same rpm range, and my understanding is how quick it does it's work is a reflection of horsepower? I am truly trying to figure this all out in my head and pardon if it is a newb question. another thought is it that the fuel is being sent to the back of the tank? and maybe there isn't enough by the pick-up? does this happen with a full tank? I know some racing tanks have little resevoirs? and lower their pick up point.
that said I will put a few chips on the timing as a major part of the problem, different vacuum advance due to load, and available vacuum.
great thread.....
great thread.....
Okay guys, my fuel volume to the carb is my problem. My timing was off a few degrees. It was at about 8 degrees idle, he brought it up to around 12 which seemed to make my motor happy. 3200 rpm put it at about 34 degrees all in. It def runs better and has a little more snap too it. But, it still bogs down on me under WOT. I ket him drive it and his first reaction was acting like it was running out of gas. Judging by the age of the fuel pump and the symptoms, he thinks a new fuel pump with a pressure regulator, along with the new sending unit should take care of the problem. He also said the carb seems to be doing it's job correctly, as it performs well when fuel is available. So I am gonna step up the fuel system so it's ready for the work about to take place this winter.
Which brings me to my next subject. I'm gonna let him rip into the top end of my motor this fall. He already has a set of roller rockers that he's putting aside for me, and he's going to do sone research for me, figure out what I'll need for parts (lifters, springs, valves, gaskets, hardware, etc) and give me a list of part numbers so I can buy all the parts first. Come fall, he's gonna rip off the heads, strip them, and send them to a machine shop he deals with to go through them. They'll get blasted, shaved down, drilled out for 3/8" rocker studs, bigger valves, & port and polish. Plus he'll get me a cam & lifters to compliment everything. After all is said and done, it'll cost me about the same as a set of Edelbrock heads, but includes the dissasembly, machine work, parts, labor & reassembly. About $1800...and he says 420hp is attainable at that cost.
How did he judge that the carb was okay? What did he look for that it was doing correctly when it was getting fuel? I might try to measure my fuel pressure coming out of the pump this weekend and see if mine isn't up to par.
I wanted to chime back in here for record purposes and for anyone else who might ever have problems. I have found the root source of the problem. A couple of years back I was at a car show and a bunch of guys were looking at my car, and how I had my fuel filter after the mechanical pump on the block. They said it was dangerous because it could catch fire if it ever leaked, so I ended up putting it before the pump after the lines come out the the frame.
Well yesterday a local guy mentioned I should try changing that. Today I bought some new lines, a new filter and put the filter on. I started the car, let it run for a few minutes and took off down the street. No carb adjustment(I had it set to from before when the filter was on before the pump) and :
(Yeah I know it's only a peg-leg, :/ It's 103' 4" without brakes, all gas.) So my question is, how does the engine starve for fuel with a Fram G2 filter before the pump, but not after? I know obviously the filter is under suction before the pump and pressure after the pump, but I don't get it.
junkyard72
Apr 3, 2013 11:16 PM
|-K|=K
Dec 22, 2010 01:35 PM
