350 vacuum question
Old May 28, 2015 | 05:46 PM
davoaz's Avatar
350 vacuum question
I got a vacuum gage and car runs a steady 17" on a warm 72' 350 100% original engine. This site says its normal. scenario 1.
http://www.secondchancegarage.com/public/186.cfm
but the gage dial I got is on the border of late timing/normal. Should I advance the timing a little to put it in the green zone? OR is 17 good and if it ain't broke don't fix it.
Old May 28, 2015 | 05:49 PM
What is your timing set to and what distributor is in there?
Old May 28, 2015 | 06:28 PM
davoaz's Avatar
Welp, Cm says each V is 4*. It is right on the 4th V to the left so 16*? It's the OEM distributor.
Old May 28, 2015 | 07:31 PM
That's a bit high for a stock points engine.
Old May 28, 2015 | 07:42 PM
don71's Avatar
same but different
Important thing , the needle is steady like you said.
17" is a little low. It should be more like 20".
If you're not experiencing any problems to relate to the reading, Its not a big deal, might just be the guages accuracy or a vacum leak.
By all means try more timing. You can always change it back.
A vacum guage is just another tool in your arsenal. Take many readings, and use an average combined with other findings you record. In other words, keep a record.
Old May 28, 2015 | 08:13 PM
davoaz's Avatar
If you're not experiencing any problems to relate to the reading.
Seems like I'm felling a slight stumble occasionally. This is what prompted me to buy the gage to measure vacuum.
Meaning increasing or backing down some?
BTW I didn't pull vacuum hose on distributor and plug like the CM says to do when adjusting the timing. Not sure if I should do that just to check vacuum and timing at idle.
Old May 28, 2015 | 09:44 PM
Timing needs to be set with vacuum advance disconnected and plugged. Have you adjusted your air/fuel mixture screws to see if you can get it a bit higher. I agree with the others although a bit low the main thing is that its steady.
Old May 29, 2015 | 05:48 AM
davoaz's Avatar
BTW, where do you get a tach and dwell meter nowadays? NAPA acted like I was speaking Chinese when I was asking about one to tune car. I had to tell them no I'm not your parts supplier.
Old May 29, 2015 | 06:21 AM
You can get one used at the usual places, I believe Sears still sells one also.
Old May 29, 2015 | 06:22 AM
don71's Avatar
same but different
Sears, Ebay or try another parts store.
I have an older Sun multi unit. Volts,ohms,dwell, tach with inductive pick up. Very handy.
https://classicoldsmobile.com/forums...omendaton.html
Old May 29, 2015 | 11:01 AM
Amazon Amazon
Harbor Freight
Sears
HARDLUCK88
Apr 22, 2009 10:39 PM
olds68
Feb 12, 2009 08:27 PM
Markie
Oct 19, 2008 05:05 PM
skryla
Mar 31, 2008 07:51 PM
77oldscutlass
Sep 5, 2007 03:36 PM
