350 vacuum parts
350 vacuum parts
Just picked up a 1969 Cutlass. Where is a good site for replacement vacuum hoses and parts? Specifically the passenger side valve cover breather? That goes up to the air filter, the part that mounts on the cover and is busted.
The rubber pieces in air cleaner, breather filter and valve cover used to be available in both Dorman and Motormite parts lines. Any newer production breather filter will prob be plastic. If you need the metal tube from breather to air cleaner that'll be a used piece.
No doubt long-ago discontinued from GM, maybe still available from Dorman.
henryk8398
June 27th, 2012 08:11 PM
