350 compression quest.
Old Apr 18, 2017 | 11:53 AM
STLCRZY's Avatar
Guys , what you think- how much compr. we have with a 350 with 8 heads and flat tops and 040 head gasket?
Heads and block would be milled to be clean....give me an idea.. 9:2:1 or maybe more ???
Old Apr 18, 2017 | 02:11 PM
cutlassefi's Avatar
Bore X bore X stroke X 12.87 will give you cylinder cc's. The rest you can do from there.
Old Apr 18, 2017 | 10:48 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Use this.
https://www.uempistons.com/index.php...ge=calculators
With the old Speed Pro's and no milling, it will be just under 9 to 1 compression. Get the machine shop to use a bowl hog on the exhaust side, there is a lip right under the valve. already has 1.625" exhaust valve. Use a 2" or 2.07" on the intake with the same treatment.
Old Apr 19, 2017 | 03:10 AM
STLCRZY's Avatar
okay i´m a little unsafe with the numbers , so maybe someone can help.
Cylinder Head Volume (cc)
8 HEADS (stock not milled) = 79cc ??
Piston Head Volume (cc)= 0
Gasket Thickness= 0,040
Gasket Bore= ??
(about .060 larger than the cylinder bore diameter,is this correct?)
355 0,30 over-Bore Diameter= 4,087
Deck Clearance not milled= ??
Stroke = 3,385
Rod Length = ??
Old Apr 19, 2017 | 07:59 AM
Piston to deck is usually .025" with Speedpro Forged pistons and Felpro's gasket bore 4.230" and 79cc is the spec, I have measured 77-78cc but 79 should work. Use decimal points, not comma's. If you want more compression with just clean up milling, Rocket Racing offers a .028" thick head gasket. With a .006" clean up on the heads, you will lose one CC in combustion chamber size. You or your machinist will need to measure everything to be accurate but 9 to 1 should be close to what you end up with.
Old Apr 19, 2017 | 11:50 AM
STLCRZY's Avatar
So with 0,006" mill on the heads and the 0,040 head gasket i would have nearly 9,9:1...??....too much!!
File Type: png
Old Apr 19, 2017 | 12:05 PM
STLCRZY's Avatar
really don´t want to mill the intake to fit.
correct me if i´m wrong - with a 0,003" mill on the heads and nearly 73 -74cc i have a roughly 9,4:1 compression ???
Old Apr 19, 2017 | 12:24 PM
I have no idea where you got 9.9:1 as I get 8.78:1 using the numbers olds 307 and 403 posted.
Old Apr 19, 2017 | 06:12 PM
You figured that with 70cc which is a big cut, you must mean a .060" cut. I would get early heads if you want that high of compression. A .006" cut= 1CC of chamber volume. So if your heads are currently 79cc, that .006" cut will reduce them to 78cc. The cut would be .030" to reduce to around 73cc, depending where you are now.
Old Apr 20, 2017 | 02:33 AM
STLCRZY's Avatar
Yeep you are right
Any cam recommendation with nearly 9:4:1
Engine goes in chevy caprice (307 olds)
mild ported 73cc Heads with 2.07" Intake/ 1.625"
Performer Intake
Stock Conv.
No headers
Highway gears
Carb..not sure for now if stay with EDE ??
Old Apr 20, 2017 | 09:18 AM
You need a cam bigger than the 204/214 for sure. Talk to Cutlassefi, he just sent me out a custom cam for my 9 to 1 350. Mine is a 214/214 on a 110 LSA as an example. Tune the Edelbrock as they seem to be way off.
Old Apr 21, 2017 | 12:21 PM
STLCRZY's Avatar
are those valves the right one:
INT:
https://www.summitracing.com/int/par...1775/overview/
EX:
https://www.summitracing.com/int/par...ake/oldsmobile
or
Old Apr 21, 2017 | 09:07 PM
Yah, those should work. Your heads already have 1.625" exhaust valves.
Old Apr 21, 2017 | 09:37 PM
coppercutlass's Avatar
Chevy budget Olds powered
I have a cam and lifters and cloyes timing chain. cam was used in one of my previous builds but good wear pattern , new lifters and cloyes timing chain . if you are intrested 125 bucks plus the ride. Its a howards 512/512 lift cam 227 /233 duration on a 110 lsa. I intalled them on the engine on the stand but i got a solid lifter cam and going with a billet cloyes chain as that engine will see much more sever use.
Old Apr 22, 2017 | 07:21 AM
Copper, that is a big cam for what he is doing, crappy highway gears, stock stall without headers in a heavy Caprice.
Old Apr 22, 2017 | 12:42 PM
Must have missed that part lol. Yeah too big for th e usage but this can you could run it with 9. 4 to 1 compression but not with that set up.
STLCRZY
Apr 1, 2012 02:03 AM
DENT
Feb 14, 2012 05:27 AM
STLCRZY
Brakes/Hydraulic Systems
Feb 9, 2011 03:21 AM
STLCRZY
Drivetrain/Differentials
Jan 22, 2011 06:48 AM
78cutlass
Mar 6, 2009 07:39 AM
