350 compression quest.
Guys , what you think- how much compr. we have with a 350 with 8 heads and flat tops and 040 head gasket?
Heads and block would be milled to be clean....give me an idea.. 9:2:1 or maybe more ???
Use this.
https://www.uempistons.com/index.php...ge=calculators
With the old Speed Pro's and no milling, it will be just under 9 to 1 compression. Get the machine shop to use a bowl hog on the exhaust side, there is a lip right under the valve. already has 1.625" exhaust valve. Use a 2" or 2.07" on the intake with the same treatment.
okay i´m a little unsafe with the numbers , so maybe someone can help.
Cylinder Head Volume (cc)
8 HEADS (stock not milled) = 79cc ??
Piston Head Volume (cc)= 0
Gasket Thickness= 0,040
Gasket Bore= ??
(about .060 larger than the cylinder bore diameter,is this correct?)
355 0,30 over-Bore Diameter= 4,087
Deck Clearance not milled= ??
Stroke = 3,385
Rod Length = ??
Gasket Bore= ??
Stroke = 3,385
Rod Length = ??
Piston to deck is usually .025" with Speedpro Forged pistons and Felpro's gasket bore 4.230" and 79cc is the spec, I have measured 77-78cc but 79 should work. Use decimal points, not comma's. If you want more compression with just clean up milling, Rocket Racing offers a .028" thick head gasket. With a .006" clean up on the heads, you will lose one CC in combustion chamber size. You or your machinist will need to measure everything to be accurate but 9 to 1 should be close to what you end up with.
You figured that with 70cc which is a big cut, you must mean a .060" cut. I would get early heads if you want that high of compression. A .006" cut= 1CC of chamber volume. So if your heads are currently 79cc, that .006" cut will reduce them to 78cc. The cut would be .030" to reduce to around 73cc, depending where you are now.
Yeep you are right
Any cam recommendation with nearly 9:4:1
Engine goes in chevy caprice (307 olds)
mild ported 73cc Heads with 2.07" Intake/ 1.625"
Performer Intake
Stock Conv.
No headers
Highway gears
Carb..not sure for now if stay with EDE ??
You need a cam bigger than the 204/214 for sure. Talk to Cutlassefi, he just sent me out a custom cam for my 9 to 1 350. Mine is a 214/214 on a 110 LSA as an example. Tune the Edelbrock as they seem to be way off.
are those valves the right one:
INT:
https://www.summitracing.com/int/par...1775/overview/
EX:
https://www.summitracing.com/int/par...ake/oldsmobile
or
INT:
EX:
or
I have a cam and lifters and cloyes timing chain. cam was used in one of my previous builds but good wear pattern , new lifters and cloyes timing chain . if you are intrested 125 bucks plus the ride. Its a howards 512/512 lift cam 227 /233 duration on a 110 lsa. I intalled them on the engine on the stand but i got a solid lifter cam and going with a billet cloyes chain as that engine will see much more sever use.
STLCRZY
Brakes/Hydraulic Systems
Feb 9, 2011 03:21 AM
