350 camshaft
350 camshaft
I am building a 69 350 w/#5 heads and flat top pistons. I need a good cam that sounds good at idle and has good torque. I don't intend to race, but I want to sound good at idle and burn a little rubber when I need to feel younger again. I'm not into grinds and degrees. Just a good cam. I can degree it in the car. I know that Cutlassefi sells cams and maybe he can help me. I need cam and gears.
Thank You,
Jim
Thank You,
Jim
The comp 280h has a real nice choppy idle and makes enough vacuum for brakes. Just make sure you run a 2600-2800 stall converter and some 3.73's and you will have a fun ride. I ran that cam and although its an old grind it worked very well.
here is what it sounded like .
