330 intake manifold
Old Sep 11, 2016 | 05:35 PM
mike1976's Avatar
330 intake manifold
Just wondering if the intake gaskets can be re-torqued after resetting the rear gasket between the block and intake? I used the fel-pro gaskets to put everything back together after doing the head gaskets.
Old Sep 11, 2016 | 07:43 PM
If your asking about reusing a steel intake gasket the answer is no. They are one time use.
Old Sep 12, 2016 | 04:14 AM
mike1976's Avatar
Thank you. I was thinking they were one time use but the guy at my local Napa was saying it should be ok to do it. I thought I would double check.
Old Sep 12, 2016 | 02:07 PM
The whole point of the steel gasket is that the beads around each port are deformed to make the seal when you torque the intake. Once squashed, they won't reliably seal again.
dave84
Jun 28, 2011 08:16 PM
fast67vellen2o
Oct 24, 2010 06:11 PM
1966_F85
May 8, 2010 07:49 PM
tmaleck
Oct 24, 2009 04:44 PM
kmccox11
Feb 27, 2009 06:51 PM
