330 Harmonic Balancer
Old Nov 9, 2012 | 07:46 PM
64OLDSPILE's Avatar
Are all 330 harmonic balancers the same?
Mine was shot, many years ago it must have gotten oil soaked and the outside part of it with the timing mark had spun.
I hadn't driven the car in many years and now I've got her out and about again. So I forgot about the harmonic balancer being shot until I decided to do a tune up check and couldn't find the timing mark. Then I remembered what had happened so many years ago, in fact it was so bad now that the outside part could be spun by hand with no problem at all.
So I bought another balancer for a 330 and it didn't look exactly the same as mine, but I figured they must all be the same and I put it on, no problems there but I still can't time the ignition. The mark is so far away from where it should be that the engine would die if I'd try to put the mark on 7.5 degrees.
So before I bought the other balancer, I just timed it by ear and it runs great but I'd like to know where I've got it set. I was excited to get the new balancer and got it put on and still can't tell where I've got the timing set.
This one does not look dramatically different from the orginal one, so my question is, are they all the same?
And if so, why can't I put my timing mark on the grid without killing the engine?
It runs really nice, lots of power, starts great.
Maybe I just have my distributer installed a couple teeth off?
Old Nov 10, 2012 | 06:44 AM
2blu442's Avatar
All 330 balancers should be the same. Some 330's didn't have balancers but since you removed one yours must have come with one. There is an early 350 balancer that looks similar, but I don't know if the timing marks are different on them. Did you already toss the bad one? If not when you put the two side by side do you see any differences? Can you post a picture of this balancer? The distributor shouldn't make a difference on the timing mark, if you put it in a tooth or two off you'd just need to rotate it or move the wires around until they're in the right location.
John
Old Nov 10, 2012 | 07:44 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Don't '64 330 balancers have the timing mark on the opposite side due to the pointer being there to clear the (opposite side from all other modern Olds V8) water pump inlet?
Old Nov 10, 2012 | 08:18 AM
2blu442's Avatar
Oops! I forgot about the 1964 having the water pump facing the other way. I remember posts saying the timing tab is on the other side. If the balancer is a 1964 only that may be tough item to find. You might have to scribe or paint the new balancer to match the correct mark. Find top dead center on the compression stroke, then mark top dead center on the balancer?
Joe P. or anybody else who really knows the 1964's online???
Old Nov 10, 2012 | 08:42 AM
Octania's Avatar
All have a balancer, as defined by the offcenter chunk of cast iron backside of the hub. Serves to balance the crank.
This hub may or may not have a DAMPER ring outside of it. Generally, pre-68, this goes hand in hand with 2bbl vs 4bbl
The following types might be found:
'64 Balancer
'64 Damper/Balancer
65-67 Balancer
65-67 Damper/Balancer
The 425 is listed in the PN manuals as using a different PN, but to me the 425 and 330 damper/balancers look the same. Same size weight blob, etc. The '64 tabs have to be different, of course, being mtd on the RH side. And a tab for a damper/balancer [larger OD] will differ from a tab for the small-OD damperless balancer.
You can (and should) verify your current damper's timing mark with say the positive piston stop method. I have used a tool made from a spark plug case and a bolt to make a quick piston stop. Then, with the timing mark verified and a tab that matches your damper, setting the timing should be easy.
How the teeth are engaged at the distributor to cam has nothing to do with getting the spark at the correct crankshaft position. That is compensated for in the setting of the timing.
Old Nov 10, 2012 | 09:48 AM
64OLDSPILE's Avatar
Alright, thanks for the info guys, my guess is this one is not from a 1964. So in the mean time I'll scribe a new TDC mark on this balancer and this winter I'll be having mine rebuilt. Thanks again, I would not have thought of where the timing index would be located on other year 330s.
Old Nov 10, 2012 | 09:54 AM
2blu442's Avatar
'64 Balancer
'64 Damper/Balancer
65-67 Balancer
Thank you for the clarification. I've wondered why some had the "blobs" while others had the damper.
John
Old Nov 10, 2012 | 12:17 PM
64OLDSPILE's Avatar
Yep, I just looked in the tune-up specs and the 64 timing index is on the passenger side and post 64 is on the drivers side. Thanks everyone for pointing that out.
Old Nov 30, 2012 | 09:47 PM
wheelman427's Avatar
balancer 330
1964 is different because the water pump is different. you can go with a newer balancer if you get the correct timing mark to go along with it.
Old Nov 30, 2012 | 09:51 PM
lower hose exits to opposite side on 1964 and maybe some 65's you can also contact FUSICK olds specialist they can or will know who can recondition your old unit. Also check HEMMINGS motors there are a number of companies who rebuild balancers to new spec.
Old Dec 1, 2012 | 05:50 AM
No, you can't use a newer balancer and timing tab unless you ALSO change to a 1965-up water pump, which means changing the radiator outlets and accessory drive.
Old Dec 2, 2012 | 08:06 AM
kjr442's Avatar
Kjr442
'64 Balancer
'64 Damper/Balancer
65-67 Balancer
I am curious about the difference in balancers,why is it that my 1965 330 with a 4 bbl has the damper, but my 1965 330 2 bbl is just a balancer? Are there more differences between the 4 and 2 bbl 330 engines? Like heads, or....... ?
Old Dec 3, 2012 | 01:15 PM
64OLDSPILE's Avatar
Yep, I read that in the service manual that all 4BBLs will in addition to the harmonic balancer, have the damper as well.
I'm not sure why, but it's there in the service manual. I'm sure somebody here knows.
Old Dec 5, 2012 | 04:14 AM
Joe you are correct I took for granted that interested parties would understand that they would need to use the corresponding year water pump since it has been adressed in previous post that the lower hose and timing mark and tags were opposite (respectively) in 1964 in relation to newer years. You could also purchase a degree wheel kit and scribe a new mark in an old harmonic balancer to correspond with a timing tag of choice or even fabicate your own and indexit accordingly.
Old Dec 5, 2012 | 07:02 AM
Joe you are correct I took for granted...
Understand. Unfortunately I've learned over the years that you can't take anything for granted in an on-line forum. If a statement can be misinterpreted, it will, so I try to be as complete and exact as possible. We continue to see people quoting some of Chris Witt's acerbic humor from the 1990s in the Olds FAQ and taking it as gospel truth or even distorting it. There was a thread on this forum not too long ago where the O.P. swore that based on what the FAQ said, only W-30s got boxed rear control arms.
rroth01
Dec 3, 2016 06:27 AM
L69
Aug 7, 2013 07:52 AM
bmbraun
Feb 25, 2005 12:17 PM
martine
Apr 2, 2004 09:25 PM
Clint Reno
Aug 10, 2003 10:03 PM
