330 exhaust manifolds
Hello,
I have a 64 jetstar with a 330. My exhaust manifolds are cracked where they bolt to the heads. I would also like to run true dual exhaust. Will these manifolds work on my car?
http://www.opgi.com/cutlass/1964/exh...folds/C240688/
I am open to all ideas and if there are headers that would fit i would love more details on them.
Thank you
Thank you
I'm pretty sure those won't work on your Jetstar. Your steering box is in the way of those rear dump manifolds. I just had duals put on mine. We had to run the crossover style pipe, and both exhaust exit on the passenger side. The crossover is behind the transmission, and the way the exhaust dump in the back is opposite of the front. It was a full day job for the pipe benders, but your steering linkage and box really complicate the job.
Hello,
Thank you
Thank you
http://thorntonmusclecars.com/produc...aust-manifolds
if the manifolds in the link are the same as what you guys are talking about they look just like the opgi ones just a bit cheaper, which i am always a fan of, still not sure how to clear the steering box, there looks like there is room, i may have to get creative.
has anyone used one of the DYI header kits?
I'll suggest that you actually compare these SBO manifolds to real BBO W/Z manifolds. The SBO manifolds are physically smaller, so I'm struggling with the concept that they are "sized internally for the 455". There just isn't room due to the SBO's shorter deck height, which is why real W/Z manifolds can't be used on an SBO. And please note that I am not bashing Thorntons, just pointing out a flaw in logic.
The Thornton manifolds are larger than the stock manifolds, they still fit as well as the stock ones and have larger outlets for the exhaust pipes, I have had the 2 on the floor side by side so this isn't an opinion it is a fact.
I have no idea what a W/Z manifold looks like but the SB Thorntons are styled after the BB manifolds, they many not be as big as a BB manifold but are larger than stock SB manifolds.
I think they helped the performance of my mild mannered car if for no other reason than I can get a larger head pipe on the engine. I think they where worth the investment, buy them direct from Thornton and save the money.
My life has been hectic ever since this thread. I still have the manifolds but I have not been able to test them. My living situation is fairly fuild. However I am in escrow now and hopefully when I move I can get some time with the car.
Oldstata helped me out with a set of manifold from a mid 70s small block a while ago. The driver side and cross over do not clear the steering knuckle on the driver side. The passenger side manifold appears to be exactly the same even though the casting numbers are not the same. This is a big help as my passenger side manifold looks like the grand canyon.
The 64 J88 uses side motor mounts that bolt to the front two of the three bolt holes in the side of the 330 block, just like the 65-70 full size cars. That's because the 64 J88 is rear steer, like those 65-70 cars.
http://www.sandersonheaders.com/sand...category_id=41
I had these in the Olds powered 4x4 but due to it being a 4x4, proper exhaust was too tight to route. It used the front holes also, sold them to a guy planning on a turbo project.
Thank you, they look like they would fit. There is only the photo on their website. I emailed them asking for more. If I stay with the stock motor those would be great. The idea is to stay with the stock block as long as there are no cracks in the block or heads.
Since this is rear steer like the later b-bodys... wouldn't this be what you'd need?
THen you can just run whatever on the pass side since they all clear. It was the drivers side that had the issues.
(sorry if i'm mis speaking... I had a 68 Delmont that had this problem back in the day, wished this part had been available back then!)
Hello,
Thank you
Thank you
#31
OP has probably found what he needed or abandoned the project altogether, as this thread is over seven years old and he's only been heard from once in the last five. Otherwise, I'm sure he would appreciate your offer.
#32
Well, that and the fact that Jetstar 88s used different manifolds than did A-body cars.
