330 cam recomendation
Old Apr 15, 2009 | 02:25 PM
RAMBOW's Avatar
Ben
Question 330 cam recomendation
Anyone have a good Cam recomendation for this...
330ci standard bore, (45deg cam angle?), 8.5.1 comp, 3.23 gears, M/T
Would like something a several steps hotter than stock.
Can i get a 330 cam off the shelf somewhere or am i going to have to get a custom grind?
Old Apr 15, 2009 | 02:31 PM
RAMBOW's Avatar
Ben
additional info...
#3 heads, will have some basic porting work done, and gasket matched intake.
Will have a edelbrock RPM intake (currently old performer 2.0 intake)
i would prefer to keep the stock rocker arm towers rather than change over to the adjustable style... but i suppose i can do that if i need to.
Old Apr 15, 2009 | 02:34 PM
RAMBOW's Avatar
Ben
Question
One more...
Am i wasting time trying to put a cam and hop up this motor with the low comp pistons in it, or would i be $$ ahead by changing out to a higher comp piston before the cam swap?
Engine runs great as is, no smoke, good o/p, just would like to get a little more get up & go out of it. If i can add another 30-40hp with a cam swap, head porting, and exhaust work that should keep me happy for a while.
Old Apr 15, 2009 | 02:40 PM
Bobsw32's Avatar
BobsW32
Even if you don't get adjustable rockers you will need to check them and possibly adjust them by shimming and or removing material from the bottom of the stand in order to obtain the proper pre-load the lifters... It takes a while to do it but can be done... When I got my 1970 W-31 in 1970 I did this to my valves to raise the rpm before valve float... That and accel points let me run the STOCK w-31 to 6800 rpm..
How many miles on the motor???? If the short block is good you can raise the compression by milling the heads and thin head gaskets.... a new cam , 4 barrel intake and dual exhaust and you would have a nice motor......without spending a fortune
Old Apr 15, 2009 | 02:56 PM
RAMBOW's Avatar
Ben
Its only got about 40k miles on it since it was rebuilt.
Was originally the 320hp high compression motor, but when it was rebuilt they used the lo comp slugs so they could run it on low octane gas.
Already has duals on it, although will eventually get headers...
I'm just starting to scheme and plan my upgrades. If i can avoid putting in different pistons to get where i want to be, i will.
Old May 21, 2009 | 12:08 PM
67htc's Avatar
I would highly recommend using the CompCams 42-221-4 camshaft for your purposes.
I have used this cam for a very similar 330 Olds project and am very happy with it.
Macadoo
Aug 13, 2015 04:26 PM
62 Cutlass Convert
Dec 18, 2014 04:42 PM
RAMBOW
Mar 7, 2011 03:18 PM
dsolomon
Mar 1, 2011 06:50 PM
panos
16
Apr 29, 2010 12:49 PM
