330 cam options
330 cam options
new member here.....would like to upgrade the cam/lifters/springs in my 330. it has factory valve train as of right now. i have an edelbrock performer intake as well as an edelbrock performer carb. i do understand that it is a 45 degree bank angle.
i am wondering if anyone has any suggestions as to what direction i should go? right now i am considering the crane cams #790531 with a set of their hydraulic lifters and springs.
http://www.summitracing.com/parts/crn-790531
not looking for anything too aggressive, just something to get it breathing a bit better and get some more power in the 1500-5500 rpm range to match the edelbrock intake power range.
i have also sent a message to cutlassefi as i have seen his name brought up in other threads about custom ground cams, hoping he gets back to me.
this is a 65 330, which i am pretty sure is a 45 degree
according to this ordering guide from crane cams, the 67 330 is also a 45 degree:
http://www.cranecams.com/pdf-tech-ti...ont270-271.pdf
HOWEVER, in this chart i found on 442.com it says all 64-67 330's are 39 degree....very confused now:
YEAR CID MODEL LIFTER DIA. CAM BANK ANGLE
1964-67 330 ALL .842 39deg
1965 400 ALL .842 45deg
1965 425 ALL .842 45deg
1966-67 400 ALL .921 39deg
1966 425 exc.Toronado .842 45deg
1966-67 425 Toronado .921 39deg
1967 425 exc.Toronado .842 39deg
1968-69 400 ALL .842 39deg
1968-80 350 ALL (gas) .842 39deg
1968-76 455 ALL .842 39deg
1975-82 260 ALL (gas/dsl) .842 39deg
1977-79 403 ALL .842 39deg
1978-80 350 ALL (diesel) .842 39deg
1980-84 307 ALL .842 39deg
1981-85 350 ALL (diesel) .921 39deg
1985-86 307 ALL .921 39deg
From my understanding the 45* cam needs to be custom ground there is a lot of threads where members have installed off the shelf ones and it was. The 39* cam I would contact
( cutlasefi ) he is a member here and can custom grind you one per your build and it's not much more or cheaper then off the shelf cams
Spoke to a gentleman at rocket racing....they offer a full package for the 330. Cam, lifters, valve springs, timing gears & chain (roller), adjustable rocker kit, etc. Its everything I need to upgrade the cam/valvetrain the right way. Price tag comes in at $1000 for everything. And he confirmed my engine is a 45 degree. They custom grind the cam based on everything else done to my car, I feel I am in good hands with their help. He asked what bolt ons I had, stall, exhaust, tranny, intake, carb, gears and should get back to me tomorrow with the cam profile he would suggest. I will follow up on this thread when I know more.
Yes I can thank you oldstata.
Cam, lifters, Cloyes Billet Double row chain set, Full roller adjustable rockers, studs, guide plates, springs, retainers, locks, $800.00 to your door, any grind.
Just left you a pm iceberg.
Thanks!!
not to thread jack, but does that mean this cam also wont work with the 64-66 330s?
http://www.jegs.com/i/Edelbrock/350/7112/10002/-1
thanks
thanks
thanks
thanks
thanks
thanks
It's simply a program change, the cam cores are the same for a 39 or 45 flat tappet. However most cam companies don't want to fool with it because of the low demand.
