307 Water pump pulley
I need to replace my water pump pulley in my 307. I bent the inner two grooves off center. The pulley itself has 3 grooves but the A/C in my Delta has been deleted.
If I'm not replacing the A/C do I still need the 3 groove pulley or will a 2 groove from a non A/C SBO line up as well?
And if I go to the scrapyard are there any other models/engines I can grab one off of that will work?
LT A1 S1
I just spent what I thought was a few minutes going back and searching threads about pulleys and when I looked up it was 3 hours later.
