307 distributor won’t come out
Old Jul 4, 2021 | 11:12 AM
deltsanddueces's Avatar
I’m in the middle of switching my 84 olds 98 to non ccc quadrajet and distributor and I took the bolt and bracket for the distributor off and the distributor will move freely but won’t come out of the block is there something else I gotta do to get the distributor out on these engines?
Old Jul 4, 2021 | 11:36 AM
don71's Avatar
same but different
Try spaying some carb cleaner at the base. Work it up and down with a pry bar of sort and keep trying.
Old Jul 4, 2021 | 11:49 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The O ring and more than likely the the oil pump drive is stuck in the bottom of the distributor. It will take some finess but should come with some effort.
Old Jul 4, 2021 | 01:54 PM
Use a hammer to gently tap it up and out.
Old Jul 4, 2021 | 01:57 PM
I did this and it worked. Thank you. I just had to stop being a wuss and give it hell
Old Jul 4, 2021 | 05:31 PM
BillK's Avatar
dd,
If you have a minute can you do me a favor and take a close up picture of your old distributor cap where the main power wire plugs in ? I especially want to see the two "hooks" that the connector clips onto.
Thanks,
Bill
Old Jul 6, 2021 | 02:04 PM
Originally Posted by BillK
dd,
Thanks,
Bill
Bill is this what u are referring to?
Old Jul 6, 2021 | 06:41 PM
BillK's Avatar
Yes, Thank you
Dec 14, 2018 01:54 AM
1969442W30
Feb 4, 2018 05:03 PM
wr1970
May 7, 2017 04:10 PM
oldsmobilty
Sep 28, 2016 06:44 PM
rcrac3r
May 10, 2012 09:34 PM
