307-403 or something better.
Old Feb 8, 2010 | 06:57 AM
86pontiac's Avatar
I have a 1986 pontiac pariseanne with a olds 307 and 7a heads. I have the 700r4 trans with I have no clue rear gear. I am planning on rebuild a motor to put into my car before I head off to college to be alittle more reliable. I was thinking of going to the junk yard and pickign up another 307, rebuilding and dropping in along with a rebuilt 700r4. But as we all know the 307 is no power monster. I am wondering if I can mybe direct swap or for cheap swap a 350 rocket or a 403 in.
Old Feb 8, 2010 | 07:39 AM
captjim's Avatar
a 403 is a direct swap, the core/engine might cost a few $ more, but that heavy car will like the extra cubes. Also, I am pretty sure that you should have a 2004r, not a 700.
Old Feb 8, 2010 | 08:06 AM
86pontiac's Avatar
well when I changed the fluid in the trans and go the filter the 700 fit, if my memory serves me right but I will check.
Old Feb 8, 2010 | 08:39 AM
70 cutlass s's Avatar
If want to make it faster you will need to change the gears. Even with a stock engine you can change the gears and see a big improvement. The 350 or 403 either would make for a good engine to swap too.
Old Feb 8, 2010 | 09:12 AM
Note that the original trans in that car is a 200-4R, not a 700R4. The 700R4 does not bolt to an Olds motor without an aftermarket adapter plate. Neither trans in stock form will live very long behind a larger motor.
Old Feb 8, 2010 | 10:16 AM
86pontiac's Avatar
What cars should I look for in the junk yard to fing a 350 or my goal a 403. My dads buick had one but wouldnt that be a buik 403 or an olds 403. I am a ford guy and have had this car for about a year now but jsut now am starting research for upgrading the slug. Would a shift kit in the stock trans be fine or would a complete rebuild and or upgrade be needed.
Old Feb 8, 2010 | 10:20 AM
All 403s were sourced from Oldsmobile. They were used in 1977-1979 B-body and C-body Olds, Buick, and Pontiac cars and the 77-79 Trans Ams.
carbonf00tprint
Nov 4, 2012 07:53 AM
reesejames
Dec 12, 2009 08:14 PM
87customcruiser
Mar 30, 2009 07:05 AM
Beeterolds
Dec 27, 2008 10:07 AM
