307 to 350 swap delta 88 to Cadillac borough need help
So my 307 took a crap spun a rod bearing I got this 350 out of a delta 88 and have mounted into the Cadillac and now all I have left to do is the vacuum and the wire harnesses can anyone direct me or help me figure out how to wire this thing up correctly and which vacuum as well as electrical I need to eliminate any help would be appreciated
Are you planning on using a computer controlled carb & distributor? If not, hook up the heavy red wire that goes to the positive side of the coil to a vacuum advance distributor. All other vacuum lines should hook up in similar locations, Olds didn't change much as far intake vacuum ports over the years. They just added a bunch of emissions stuff.
If you're swapping carbs and doing away with CCC, you'll need a non-CCC distributor. When I did the conversion, there was a harness on the driver's side firewall for all of the basic engine controls and gauge sensors, and a harness on the passenger side firewall for all of the computer-related functions. Not sure if the layout is the same on your Cadillac. I bought my car with no motor, so all I had was wires. I went through and identified and tagged each one, and when I had determined that I wouldn't need anything from the passenger side harness, I removed it and plugged the hole. My suggestion for you would be similar. Separate the two harnesses, and identify all of the wires with the wiring diagram, to make sure there's nothing in the computer harness that you need. If there's not, you can remove it. My swap included going to an old TH350 and eliminating ALL other options. Be aware that you may have some options that will be affected or need special attention, such as cruise control, AC, torque converter lock-up, digital speedo if so equipped, etc. I only mention this as I don't know the specifics of these things as they apply to your car, and you'll want to investigate them if they matter to you.
Edit: As I recall, there is also one wire from the passenger side AC box area that makes its way over to the driver's side, for the high blower setting relay. You'll want to identify this, and also check the connector, as it has a tendency to melt and may need to be repaired.
Got it! Thanks I went with the older carb until I get a better intake to go with my performance carb, only thing I'm wondering about is the problem with the transmission not able to shift into overdrive without the computer telling it to
The 200-4R is NOT computer controlled for shifting. It will shift into OD just fine on it's own. The only thing the computer does is control the converter lockup. You can do the same with an aftermarket lockup kit or even a toggle switch.
Carbs!
So I have just about everything set up on this engine for now until I get some more disposable cash my question is what's the largest carberator I can put on this think I have a 750 and a 650 cfm carb are these to big?
DeadBang1968
January 19th, 2011 06:35 AM
BIGT82
July 11th, 2010 06:35 PM
