2 groove crank pulley
Can anyone tell me if this pulley will work(fit) on a 77 350? I might be needing a 2 groove for clearance reasons on my 47 coupe build. I won't be running AC, so that is not a concern.
http://www.ebay.com/itm/1968-72-442-...gAAOSwIzNXPgNA
It should, but the problem is you would need the correct length water pump with the correct pulley to match it up. You can't just swap pulleys with an Olds and expect everything to line up. Kind of a pain, but that's how it is.
Dennis, I've got a set from a 1967 Toronado that are two groove and fairly thin. Please send me a reminder on Saturday and I'll look for them.
I've got a friend with a street rod and he found a three groove crank pulley that he cut the outer groove off of due to lack of clearance and made it work for him.
John
John
Thanks John, by a set do you mean water pump, power steering and alternator pulley too? Or do I just need the water pump pulley to match? I have actually thought about cutting the outer groove off of mine, but I was leery of doing it.
