2 to 4 BBl conversion
Old March 6th, 2012, 08:04 AM
jrmandryck's Avatar
Hello all, this is my first post to the forum. I have a 1971 Olds Cutlass, 350 2 barrell, automatic, 56k original miles. I searched the forums and found a few threads that work around this question but the one focused more on the trans swap so hear it goes...
What do I need to buy to convert my 1971 350 2 barrell to a 4 barrell set up? I have purchased a 1971 4 barrell intake, and am debating which Edelbrock carb to be either square bore with an adapter or spreadbore.. What else will I need to do this all at once? thanks for your help
jrmandryck is offline
Old March 6th, 2012, 08:37 AM
TenMidgets's Avatar
X2 - I am a curious novice as well.
TenMidgets is offline
Old March 6th, 2012, 08:44 AM
I would find a rochester 4v for your stock manifold. I have done this using an edelbrock and you will need the spreadbore to squarebore adaptor. It's about 3/4" thick. I'm not saying that the edelbrock carb won't work, it will work nicely. But after playing with both carbs on my 330 for 2 years, I found that I liked the rochester better for all around performance!
oldcutlass is online now
Old March 6th, 2012, 09:21 AM
Rickman48's Avatar
X2 on the Q-Jet!
Since offered stock on the car, all factory parts can be used, without modification.
Rickman48 is offline
Old March 6th, 2012, 11:02 AM
jrmandryck's Avatar
So just a carb, everything else is a direct bolt on then?
Old March 6th, 2012, 11:46 AM
Not quite that easy....
NO!
I did a 2bbl to 4bbl swap in 2008. I used a
- 7042250 quadrajet - restored ( I believe the one for 71 is 7042150) Also need the base gasket and air horn gasket.
- 4bbl quadrajet fast idle solenoid (will plug directly into same connector for 2bbl one)
- 4bbl intake manifold - I didn't play around with adapters. A stock 4bbl intake manifold for your car is cast iron and is designed specially for the Q jet. It weighs a lot though. If you decide to go to an aftermarket that's ok too, just so long as it's designed for your engine and 4bbl carb
- 4bbl throttle cable (different than 2bbl)
- 4bbl throttle cable bracket (bolts to back 2 bolts of carb - it's different than 2bbl)
- new intake manifold gasket set
- 4bbl air cleaner (2bbl will not fit. The air horn is different diameter)
- replace thermostat/gasket and connecting hose
- transfer water valve at back right of manifold, or buy new one.
- transfer idiot light/gauge sensor to new intake
That's pretty much it. My car is not AC. You will also have to play with the fuel mixture to get the right settings for a 4bbl. They are in the 71 CSM if you need them.
Allan R is offline
Old March 6th, 2012, 03:25 PM
jag1886's Avatar
Either get a Q-Jet or a Holley 4175 spreadbore for the manifold you have or get a 65 4BBl intake if you want to run an Edelbrock, it bolts right on. What ever you do don't use an adapter plate.
jag1886 is offline
Old March 6th, 2012, 05:56 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
A good carb for the street, works on either square or spread bore intakes, is the new Street Demon. It is basically a modified Thermoquad, with either the plastic(polymer) or aluminum main body. They made it a 3 barrel so it would flow 625 cfm and still fit a square bore manifold. It has small primaries and will be very comparable to a Qjet mileage wise. Holley now owns the Demon line, so quality issues should be gone.
olds 307 and 403 is online now
Old March 6th, 2012, 06:11 PM
Allan, you forgot to tell him he'll need a new fuel line, too, unless he can wrestle the original into the right position.
MDchanic is offline
Old March 7th, 2012, 06:40 AM
jrmandryck's Avatar
I already have an intake (cast iron) and have been looking at some aftermarket spreadbore carb (I have had an edlebrock for years on various cars and never had a single issue with them so would like to stick with them)
Old March 7th, 2012, 10:42 AM
D'ohhh!!! Yup slight brain fart there. If he tries to do that he'll probably end up putting a bad kink in it or cracking it. My bad - thx Eric!
Allan R is offline
Old March 8th, 2012, 05:12 AM
jrmandryck's Avatar
Thanks for all the help guys
Old March 8th, 2012, 06:48 AM
delete
droptopron's Avatar
If you have a rebuildable core Q-Jet or want to buy one done check these guys out.
www.everyday-performance.com
I had them rebuild my Edelbrock QJet and was pleased with the work & the price.
droptopron is offline
ohiocutlassparts
September 13th, 2017 09:29 PM
Uncle Hulka
December 28th, 2011 08:17 PM
scott_442
January 21st, 2009 05:19 AM
rontiac
March 24th, 2004 01:26 AM
Quick Reply: 2 to 4 BBl conversion
