1966 330cui Rocker arm bolts
Old April 10th, 2018, 12:24 PM
Haidda's Avatar
hi guys! can someone tell me which bolts are used for the Original Steel Rocker Arms (the hex bolts, grade 8)? Diameter and Lenght! Sorry for such a simple question but i am Not familiar with "inch" i am a Matric guy and dont want to Order Somthing wrong
thanks and br
daniel
Haidda is offline
Old April 10th, 2018, 01:11 PM
jcdynamic88's Avatar
offhand i don't know the exact dimensions of them but i believe i have extra set if you don't need new or maybe you can get new local to you idk,jc
jcdynamic88 is offline
Old April 10th, 2018, 04:50 PM
lemoldsnut's Avatar
They were the same 65-up
I also can provide them if needed
Larry
lemoldsnut@aol.com
lemoldsnut is offline
Old April 10th, 2018, 06:18 PM
Sugar Bear's Avatar
Original should be 5/16" diameter, 18 threads per inch (sometimes referred to as course thread) and grade 8. Sorry I do not know the length.
You'd be better with factory bolts as they are not threaded all the way, they have some shoulder remaining and a flat washer like top built into them.
Sugar Bear is online now
Old April 11th, 2018, 01:26 AM
Haidda's Avatar
I need 3pcs. Is it possible for you to ship overseas? Bolts are not available in Austria.
BR Daniel
Haidda is offline
Haidda
Brakes/Hydraulic Systems
March 17th, 2017 03:53 AM
Macadoo
February 10th, 2016 05:32 PM
nolabigdawg
October 25th, 2014 11:50 AM
Oldssupreme
February 6th, 2013 12:39 AM
olds69er
October 29th, 2010 03:16 PM
Quick Reply: 1966 330cui Rocker arm bolts
