1966 330ci High Compression?
i believe the 330 in 66 was high compression (10:25 : 1 ) on the 4 barrel intake applications...
2 barrel had a lower compression ratio (9:1)
V8 - 330 2-BBL250 @ 4800335 @ 2800 (bore x stroke) 49.63.938 x 3.385 CR 9:135
V8 - 330 4-BBL320 @ 5200360 @ 3600 (bore x stroke) 49.63.938 x 3.385 CR 10.25:135
Yea, I went to high school with a guy that looked just like your avatar. YES... he was creepy! I do remember Clockwork Orange... strange stuff for sure!
Sooo... back to the OP. There should be a W stamped on the head after the numbers. I think that's suppose to indicate a high compression 330?
Just checked the heads and they do indeed have a 'G' stamped on them. The gas cap also says 'Important Use Premium Fuel Only' I appreciate all the good information everyone. I'm happy I have the high compression engine but it just seems sluggish to me. I guess I'll have to fix that with the big block and the Tri-Carb setup
Thanks,
George
Thanks,
George
Thanks,
George
Thanks,
George
Thanks,
George
Thanks,
George
http://wildaboutcarsonline.com/cgi-b...aldisplayed=50
Wild About Cars. http://wildaboutcars.com. An information supersource, especially Oldsmobile. More Olds content than anywhere else on the internet and continuing to grow.
You'll find Chassis Service Manuals, Product Information Manuals (AKA Assembly Manuals), Inspector's Manuals, and other documents that will contain this and much much more.
Dealer Brochures, magazine ads and articles, and the Automotive History Preservation Society library growing daily.
Free to join, free to learn.
Check and make sure the transmission switch pitch function is working correctly. If it's not it can be a real dog. Engine timing is also very important. Also ensure your throttle linkage is opening the carb all the way at WOT.
High
Tedisthebestkingintheworl
May 29th, 2014 02:43 PM
cts-v
January 10th, 2009 05:55 PM
