1964 Olds 330 Cui - Frankenstein Build
Old Oct 30, 2020 | 11:47 AM
Nic_The_Cutlass_Guy's Avatar
Hi
This is Nic from Switzerland
i`m working on a 1964 - 330Cui Oldsmobile Engine for my 1964 Cutlass.
I got the block bored up to 350Cui, got fitting Flathead Pistons (Seald Power L-2320F / for Oldsmobile)
Aswell a Custom Camshaft (45degree, Dur@050 Int.224 Exh.236 / Lift Int.504 Exh.512) using "Regular Lifter" (Non Rollers)
Crankshaft redone with fitting Bearings etc. & everythings fits nice at the moment.
Now i found some Olds 7A Heads. I got those redone too like new out of the box, but here are the questions i have.
1. Question, will these Olds 7A Heads fit with my Flat Top Pistons?
For the 7A Heads i would like to use Harland Sharp Rockers "S4004 AMC/OLDS" 1.6-3/8 stud mount rockers with locking nuts, and Comp Cams 4542-16 5/16 to 3/8 pedestal
to stud conversion studs for an Olds, and Comp Cams 4842-8 pedestal to stud conversion guide plates for 5/16 (Std. diameter) push rods also made for an Olds.
2. Question, does anyone know the pushrod length for best / fitting valve train geometry with the these Harland Sharp Rockers?
Thanks for all your help
Nic
Old Oct 30, 2020 | 02:15 PM
oldsmoboogie's Avatar
I cannot answer your questions but i am curious as to where you purchased that camshaft?
Old Oct 30, 2020 | 05:48 PM
Custom Camshaft
https://www.bulletcams.com/Crankshafts/CrankInfo.html
or "dick miller racing" could help you too..
Old Oct 30, 2020 | 06:04 PM
Oldsmaniac's Avatar
Buying pushrods is the final thing you do when the valve train is assembled you must measure. It is best to get just a little preload on the lifters, just enough to keep the rockers from tapping. If your rockers are adjustable then you have a little margin of error on pushrod length as you can fine tune the lifter preload.
Old Oct 30, 2020 | 06:34 PM
Which "7A" heads? The 1972 heads with the 7A or the 1980s 307 heads with the 7A?
Old Oct 30, 2020 | 08:03 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
You need to CC the heads and measure how far the pistons sit from deck at TDC to figure out compression. You have a more aggressive camshaft, which will help but may be over 10 to 1 compression. I assume you plan on running Premium gas? What octane is your Premium gas there?
Old Oct 31, 2020 | 02:17 AM
Oldsmobile 7a Heads
Old Oct 31, 2020 | 02:24 AM
we have 95 Octane Unleaded or 98 Octane Unleaded fuel in switzerland (Europe), but for the goods of the old engine i added always "lead replacement additve" (Liqui Moly Lead Substitute)
Old Oct 31, 2020 | 02:29 AM
Right okay. i have a adjustable checking pushrod to measure it somewhere, thanks! will try my best and hopefully find fitting ones.
Old Oct 31, 2020 | 05:24 AM
Sugar Bear's Avatar
The pictured heads should have hardened valve seats. Can someone confirm? The lead substitute won't be needed any longer.
Good luck!!!
Old Oct 31, 2020 | 06:06 AM
Good luck!!!
All Olds heads from the 1971 model year on have hardened seats, but keep in mind that this is just local induction hardening of the cast iron and not a separate pressed-in seat. The first time you cut the seats, that hardened layer is removed.
Old Oct 31, 2020 | 06:10 AM
Sugar Bear's Avatar
Thanks Joe, I was unaware of that.
Old Oct 31, 2020 | 07:17 AM
cutlassefi's Avatar
That’s RON, different standard than ours. You’ll need to run your 98.
Old Oct 31, 2020 | 10:51 AM
Custom Camshaft
Thank you, i tried Bullet cams a couple of weeks ago and they do not have any blanks. I will try Dick Miller.
Old Oct 31, 2020 | 11:08 AM
Still, Question will these Olds 7A Heads (Valves) fit or squash with my Flat Top Pistons? Thanks for your feedbacks
Old Oct 31, 2020 | 05:00 PM
cutlassefi's Avatar
Unless you have crazy lift on a tight LSA then don’t worry about valve reliefs.
And I have access to Olds cam cores, both for flat tappet and roller.
Old Nov 3, 2020 | 04:35 AM
Thanks for your Updates!!
i will move on with the "Frankenstein" and let ya`ll know what gone happen. hahaha
Greetings
Nic
Scott Brandenburg
Apr 12, 2020 08:33 AM
Kyle's77cutlass
Apr 8, 2019 10:55 AM
71DP
Jul 2, 2017 03:11 PM
InfoJunkie
Tech Editor's Desk
May 3, 2011 09:32 AM
Oldwolf
Nov 17, 2009 07:48 AM
